Results 1 to 15 of 19
Thread: Help selecting mill bit
24th May 2022, 01:38 PM #1Senior Member
- Feb 2013
- Bunya Mountains, Australia
- 69
- 182
Hi,
I'm helping a mate with his model railway. I need to mill quite a bit of brass (hoarded by my mate over the years) to build his loco shed. But never mind the details.
The brass ranges from 20mm x 5mm bar and lesser. The idea is to cut scale girders from these bars.
My little mill I only ever use for precision drilling. So my question is, would this be a suitable bit to buy for the purpose of both facing and depth cutting.
https://www.endmill.com.au/3-flute-u...r-soft-metals/
Thanks in advance.
Greg
24th May 2022, 03:42 PM #2Most Valued Member
- 4,890
Probably be okay, you haven't mentioned much about the type of machining you will be doing, HSS slot drill or HSS end mill may suit your task as well, depending on what you are doing will generally govern the type of cutter, you may also want to consider if you will need any long series cutters.
24th May 2022, 05:59 PM #3Senior Member
- Feb 2013
- 69
- 182
Thanks for the answer,
The idea is to cut the brass bar into I-beams and trusses. At the moment the 3 on the left are (scaled up 160x) 1.6m wide and 0.48m thick. They have to be thinned and diamond or circle patterns cut through their vertical sections.
Basically they have to be thinned down and resemble a truss
So if you could recommend, then i'm listening
24th May 2022, 06:53 PM #4Most Valued Member
- Healesville
- 2,129
For the I beams carbide slot and end mills are probably a better choice as they are pretty cheap on aliexpress and you will get a better run out of them than the carbon end mills. https://www.aliexpress.com/wholesale...list.1000002.0
For the trusses i would see about getting them done with water jet, if you are going to try to machine all those thin webs you are gunna be taking tiny cuts trying not to bend them away from the cutter, you would need a lot of time and swear words and then finish all the corners with maybe a triangle file depending on what angle you choose and more swear words.
24th May 2022, 07:04 PM #5Senior Member
- Feb 2013
- 69
- 182
Thanx for this one.
For this type we were just going to cut away as much swarf as possible and then finish with triangle files. Brass is easy to file. So I could just use a drill to cut the biggest circle allowed and then file. But it would be handy to slot sideways as well. All the time keeping the bar at max thickness, and only surface thin it after the cuts. Would that work?
24th May 2022, 07:13 PM #6Most Valued Member
- Healesville
- 2,129
24th May 2022, 09:07 PM #7Senior Member
- Apr 2007
- Newcastle
- 229
I have to ask what the rest of the model train world does?
Surely they're not all machining sections up?
24th May 2022, 09:31 PM #8Most Valued Member
You could also try using a scroll saw to cut out your triangles.
24th May 2022, 09:54 PM #9Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,553
I’d be looking at punching them. Depending on the size you may be able to get a relatively cheap triangle jewellery making punch off the shelf.
24th May 2022, 10:27 PM #10
Hi Mutawintji,
Yes this the way I would go as well ! A sheet of 0.5 mm hard brass big enough for you to get all your parts out of. Using water jet, or Laser for that matter would mean that all your parts would be Identical and uniform in size. You would have to supply a DXF file with a drawing of your parts.Best Regards:
24th May 2022, 11:18 PM #11Most Valued Member
I assume you mean 1.6cm x 0.48cm?
I.e. 16mm x 4.8mm
I.e. ⅝" x 3/16"
It would be a lot easier to buy pre-made brass trusses. And probably cheaper than paying someone to water jet or laser cut them for you. These are 7.5mm tall. Two of them would give you 15mm, which is close to your 16mm:
https://modelshop.co.uk/Shop/Strip-S...engths/ITM1922Chris
25th May 2022, 08:38 AM #12Senior Member
- Feb 2013
- 69
- 182
25th May 2022, 08:40 AM #13Senior Member
- Feb 2013
- 69
- 182
25th May 2022, 08:42 AM #14Senior Member
- Feb 2013
- 69
- 182
26th May 2022, 01:06 PM #15Senior Member
- Feb 2013
- 69
- 182
I was buying a few drill bits at Equipment Sales, Kingaroy. When I spied this on the shelf, they appeared to be the only mill bits in the whole place. Dirty, dusty, musta been sitting there for years.
Can anyone recommend the best speed for brass for the 4 mill bit?
Greg
1803A2AB-6C05-4380-9981-A8674F173044.jpg 3932A07B-FFB0-4140-8F66-5991E80A7F7A.jpg276A0055-9782-41A5-95E6-1F0E5834D152.jpg C0F5C2CD-55DF-446F-8E38-FC1F45EE3CDE.jpg
Selecting & Sourcing a VFD
By Salv in forum ELECTRICALSReplies: 11Last Post: 25th May 2022, 05:27 PM -
Selecting the right grinding grit
By KBs PensNmore in forum GENERAL DISCUSSION / OFF TOPICReplies: 0Last Post: 24th Oct 2016, 07:35 PM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Selecting capacitors for motors
By Garry 3 in forum METALWORK GENERALReplies: 5Last Post: 24th Nov 2011, 06:40 AM -
Advice on selecting a mill
By krisfarm in forum METALWORK GENERALReplies: 13Last Post: 7th Jan 2010, 02:25 PM
