Results 1 to 8 of 8
Thread: Small Surface grinder
5th May 2022, 08:28 PM #1Golden Member
- May 2020
- Willowbank QLD
- 535
I would like to incorporate surface grinding capability into my workshop. I only intend grinding small items such as thrust washers and such.
I like many have a couple of limitations, space and available funds.
Are there any really small surface grinders that are worth owning or is there another way to achieve surface grinding on a budget.
Thanks Steve
5th May 2022, 09:34 PM #2Philomath in training
Power made a small SG - all hand cranked (I have one of those), as did Macson. Hard to find though.
You may be better off looking at small T&C grinders as most of those look like they would take a small mag table. The only downside is that the down feed may not be as fine as on a S/G. A couple of members have CC T&C grinders and might be able to advise whether they could take a small mag table.
5th May 2022, 10:49 PM #3
I use a small mag chuck on my vintage C.C. Engineering T&C grinder. Quite successful actually.
Cheers, Joe
6th May 2022, 02:08 AM #4
When I made my Modified Brooks T@CG one of the considerations was whether I could do any rudimentary surface grinding ! The column is on a M10 X 1.5 threaded screw and although the thread is quite coarse, I can easily move in very small increments. I don't have a magnetic chuck but have got away with using powerful magnets salvaged from old computer hard disc drives and an aluminium fence. If needed the grinding head can be swung through 90 degrees and the length of table gives you about 6 inches by 3 inches. With the M6 threaded drive spindles a 1 thou positioning is quite achievable.
Have a look at https://metalworkforums.com/f303/t20...oks-tc-grinder
For my build log !
HTH.Best Regards:
7th May 2022, 11:23 PM #5Most Valued Member
- Healesville
- 2,129
Steve you could probably build a simple flaring cup wheel grinder fairly easily, you would need something like a small mag chuck and an electric motor with a cup wheel fitted to the shaft, the motor would be mounted to a column via arms and have a mechanism to adjust the height of the motor/cup wheel in relation to the job to be ground, the motor/cup wheel is pivoted on the column from side to side by hand to advance the wheel across the job.
Here are some examples.
https://www.machinestock.com/en/mach...+2#prettyPhoto[diashow]/2/
https://www.machinestock.com/en/mach...achine/ATHENA/
https://www.werktuigen.com/delta-lf+350/wt-660-0934
8th May 2022, 02:10 AM #6Senior Member
- Aug 2007
- 292
I've wondered if a radial arm saw could be used as a rudimentary surface grinder. With a grinding wheel in place of the saw blade and lowered slowly in theory it would mimic a metal shaper with a wheel rather than a cutter. Anyone know if it has been tried before or reasons why it won't work? I was thinking along the lines of an older industrial saw rather than a hobby machine.
Pete
8th May 2022, 03:17 AM #7China
- Dec 2005
- South Australia
- 1,658
I do not believe the bearings on a Radial Arm Saw would be accurate enough to give a truly level finish
8th May 2022, 04:21 PM #8Most Valued Member
Even the movement on the arm of the saw would negate any form of required consistency. IMHO
Help with Fair price for small surface grinder
By Danger Mouse in forum METALWORK GENERALReplies: 8Last Post: 12th Aug 2021, 09:12 PM -
Small rotary table surface grinder
By elanjacobs in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 3rd Aug 2020, 07:54 PM -
Surface Grinder or T&G Grinder, which is best for adapting?
By TommyGMachining in forum METALWORK GENERALReplies: 6Last Post: 18th Jun 2019, 09:13 AM -
Needing Some For A Small Surface Grinder Job in Melbourne
By thumbsucker in forum METALWORK GENERALReplies: 60Last Post: 17th Nov 2015, 02:33 PM -
Building a small surface grinder
By jhovel in forum METALWORK GENERALReplies: 20Last Post: 14th Sep 2011, 11:30 PM
