Results 46 to 51 of 51
28th May 2022, 06:43 PM #46Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
My 120L vertical sydney tools air compressor worked great with a super cheap auto hand held sand blaster i soda blasted a whole dirt bike aluminium engine it came up like brand spankin new but when i used the die grinder the air compressore was useless
Mine was 17cfm and i only got free air for around 70-80 seconds at 90psi before the motor kicked in
Best way is to dial down your psi so u use the least amount of air and still be able to sand blast that way u get more duty out of the compressor
28th May 2022, 09:14 PM #47Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Free air is what the compression head/s can deliver straight off the port, not the headroom between tank pressure and motor start pressure. If it was we’d all have gigantic receivers and the problem of free air delivery wouldn’t exist.
29th May 2022, 08:06 AM #48Member: Blue and white apron brigade
The way to assess if you compressor is really delivering 17 CFM is to time how long the recharge takes and to check the start and stop pressures.
For example - lets assume 30 secs to recharge from 90-120 Psi.
That's a change of 30psi, or 2 atmospheres.
2 atmospheres worth of tank = 2 x 120 = 240L, in 30s or 480/min = 16.95 cfm.
31st Oct 2022, 01:40 PM #49Diamond Member
- Jun 2010
- Canberra
- 1,322
Had to replace a compressor where I work - it was an angry little direct-drive unit that made a hell of a row, and often vibrated across the floor until it unplugged itself. I've been waiting more than 10 years for it to die, but it steadfastly refused to until last week.
It's a non-critical machine, so I was considering just getting another of the Supercheap "silent" compressors, but instead got a little Hush 50 unit from Sydney tools. While I've noted that the Supercheap machine doesn't seem to be particularly quiet, this Hush unit really is considerably quieter - much nicer to have around, and it sits still. I'm seriously considering selling the Supercheap machine I've got and replacing it with one of the 3 or 4 pump Hush units.
2nd Nov 2022, 09:21 PM #50Most Valued Member
- Mar 2011
- 1,552
I’ve been using my 50L direct drive for the last couple of months while I get the shed sorted to a point of unpacking stuff off pallets. On Monday I took my 3 motor compressor off the pallet it moved house on. It’s night and day. If you do decide to buy one you will certainly notice the difference.
1st Feb 2023, 04:02 PM #51Golden Member
- Apr 2019
- 596
If you want to advertise, make sure you pay the forum admin.....................
Lathe shopping
By Raggsie in forum METALWORK GENERALReplies: 32Last Post: 25th Jan 2022, 10:12 AM -
TIG Shopping List
By NedsHead in forum WELDINGReplies: 22Last Post: 23rd Oct 2020, 07:04 PM -
Shopping list to convert to CO2 MIG (well GMAW really)
By WelderMick in forum WELDINGReplies: 18Last Post: 10th Feb 2015, 10:13 PM -
What criteria do you use when shopping for tools?
By Grahame Collins in forum METALWORK GENERALReplies: 30Last Post: 22nd Sep 2014, 07:49 PM -
Shopping for a new lathe
By th62 in forum METALWORK GENERALReplies: 19Last Post: 16th Jul 2013, 12:33 AM
