Results 16 to 30 of 51
3rd May 2022, 03:38 PM #16Golden Member
- Apr 2018
- Drouin Vic
- 634
3rd May 2022, 05:09 PM #17Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
In the same manner that ‘assembled right here in Brisbane’ means SFA..
I’ve sort of adopted the position that if I can’t buy Australian made, I will buy Australian assembled because at least on some level that means a business is employing Australian workers. However I have no qualms in cutting out the middleman if the quality isn’t there against the straight out import.
3rd May 2022, 05:28 PM #18Senior Member
- Jun 2020
- Freo
- 68
- 142
does anyone know what material is used to form the seals/rings in these silent type compressors. I was given one by a dopey mate that had it beside him while spray painting. Needless to say it ingested a lot of overspray and stuffed up the seals. I have tried a couple of slippery plastics like nylon but they don't last long. I would love to resurrect it
Super cheap and repco both had a Stanly 2 motor version on sale for a bit over $400 so i picked one up as i can have it inside the shed and not drive me nuts.
Bloody mobile photos rotated
3rd May 2022, 07:19 PM #19Most Valued Member
- Mar 2011
- 1,555
https://www.hireexpress.com.au/files...s/110010_O.pdf
If by seals you are referring to the piston ring, part 13 in the exploded diagram on page 7 then it’s probably something along the lines of carbon impregnated Teflon
3rd May 2022, 08:24 PM #20Diamond Member
- Jun 2010
- Canberra
- 1,322
I bought one of those Stanley units from Supercheap. I have no idea what the comparison must be to call these things “silent”, but it must be something like a jet engine, as it’s not term I’d use to describe it. They’re pretty damn loud, at best similar to a belt drive, but at a higher pitch. Would be curious to see how the Chicago units compare.
3rd May 2022, 10:36 PM #21Senior Member
- Jun 2020
- Freo
- 68
- 142
4th May 2022, 08:56 PM #22Most Valued Member
A mate of mine has one similar to this and it's brilliant.
His has 3 motors and depending on the required air needed, you can run 1,2 or all 3 motors. Very quiet too.
If I was in the market for a compressor I would be looking at a similar unit.
Sent from a galaxy far far awayGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
4th May 2022, 10:49 PM #23Golden Member
- Apr 2018
- Drouin Vic
- 634
Had a couple of brief opportunities in a very busy day today, got to have a look at a few in two different shops . The Chicago Air is looking like the lead contender at this stage.
5th May 2022, 01:13 AM #24
Did you see the new Peerless 240v scroll type compressor?
I've got the Peerless P20 high flow Fatboy, 110lt tank 3.5hp 240v/15A works pretty good but does seem to be a little bit lower quality compared to my old Clisby "RIP"....................................................................
5th May 2022, 04:22 PM #25Senior Member
- Sep 2009
- Newcastle
- 342
5th May 2022, 04:33 PM #26Most Valued Member
7th May 2022, 12:59 PM #27Golden Member
- Apr 2018
- Drouin Vic
- 634
Yes the peerless screw compressor looks great but 4 or 5 times the price of a piston unit of similar output. Not sure who it's aimed at but it aint me, not even 'maybe one day'..
I've been wondering about those units with multiple heads that can be individually switched on or off; what advantage is there when you're filling the same tank? Wouldn't switching one off just increase cycle time, take the same amount of energy to put the same amount of air in the tank over a longer time? If you could also shut down half the tank when requiring less air, I could see the sense in that but I'm wondering if this is just a gimmick?
7th May 2022, 04:31 PM #28Most Valued Member
- Mar 2011
- 1,555
Whilst I can turn the power heads on mine on and off individually, I don’t. Likely you won’t either if you buy one.
The advantage of the individual heads is that if in the event of things getting hot it goes into thermal cut off, it’s only the head that’s at that point that stops. I’ve only seen that happen twice, both times on days over 40 and the compressor had been running for an extended period.
7th May 2022, 05:51 PM #29
7th May 2022, 05:59 PM #30Most Valued Member
Less noise if you have neighbours close by and you want to run it at night.
Lathe shopping
By Raggsie in forum METALWORK GENERALReplies: 32Last Post: 25th Jan 2022, 10:12 AM -
TIG Shopping List
By NedsHead in forum WELDINGReplies: 22Last Post: 23rd Oct 2020, 07:04 PM -
Shopping list to convert to CO2 MIG (well GMAW really)
By WelderMick in forum WELDINGReplies: 18Last Post: 10th Feb 2015, 10:13 PM -
What criteria do you use when shopping for tools?
By Grahame Collins in forum METALWORK GENERALReplies: 30Last Post: 22nd Sep 2014, 07:49 PM -
Shopping for a new lathe
By th62 in forum METALWORK GENERALReplies: 19Last Post: 16th Jul 2013, 12:33 AM
