Results 1 to 9 of 9
Thread: 400mm Sump Pump Pipe
2nd Mar 2022, 10:22 PM #1Most Valued Member
- 70
- 1,513
Anyone know where I could purchase about a metre of approx 400mm poly pipe to make a pit for a submersable pump?
Nev.
3rd Mar 2022, 12:19 AM #2
Hi Nev,
Would someone like a drainage company have plastic lidable chambers ? The one in my front garden is about three feet in diameter and is in two three foot sections, it has a rectangular steel lid that contains blocks to match the path. From memory the lid is sat on a row of house bricks set in concrete surrounding the top.
The original concrete pipe that formed the chamber had collapsed from tree roots and builders debris thrown in around it, probably damaging it and why the concrete broke up. The replacement plastic has had concrete poured in around it.Best Regards:
3rd Mar 2022, 02:02 AM #3Senior Member
- Aug 2007
- 292
A number of years ago the municipality was installing sewer pipes along some roads nearby. There were lots of offcuts anywhere from 2'/600mm to 6'/1800mm long. They were PVC and about 32/800mm across and about 1'/25mm thick. I asked if I could have a couple pieces and the crew said "Sure take all you want." Check out your city/municipality works yard and if they have any they might give them to you. Developers might do the same.
Pete
3rd Mar 2022, 07:47 AM #4
Hi Nev
Maybe here- second hand ???
https://www.nkf.net.au/hdpe-poly-pipe VARIOUS DIAMETERS AND HEAVY WALL THICKNESSES
It is near Toowoomba by their website.
Scroll down the page where there is a grouping on 400mm pipe at $110 P/metre.
I hope it is what you need.?
3rd Mar 2022, 08:31 AM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
I've used ME Christensen at Logan Village in the past to make industrial size and strength plastic buckets from SWVP. They supplied the pipe made a bottom cap and glued it all together for me.
3rd Mar 2022, 04:14 PM #6Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Maybe Soakwell components might work for you?
3rd Mar 2022, 06:58 PM #7Most Valued Member
- 70
- 1,513
Thanks guys. Have made a temporary pit using a plastic waste bucket for now. Filled around it with drainage gravel with lots of small holes around the circumference close to base. Some 50mm drainage hose and a few fittings from Bunnings and it's good enough for now I think. Needed something now rather than later, even though I have to turn the pump on and off when needed, as pit is not deep enough for float switch to operate. I think the Real Estate may be sending a plumber in about a week, to see if we can work out a permanent pit and pump solution. I am not fit enough to do it myself and seeing as I rent, I would rather go through the Real Estate and owner about this. I had an Italian made submersible pump stashed away here for years so used that. They are about $550 now. 130Ltrs a minute I think. Paid $100 for it new from Cash Converters. Had storms here again this morning.
Nev.
4th Mar 2022, 11:56 AM #8New Member
- Jun 2021
- Canberra
- 8
Bit late, but I'd use a 60L plastic rubbish bin from Bunnings. I have used them in the past to stop holes dug for concrete footings collapsing in on themselves. Cut the bottom off, insert footing, fill with concrete.
4th Mar 2022, 07:40 PM #9Most Valued Member
- 70
- 1,513
Sump filter.
By Hoggo1951 in forum AUTO RESTORATIONReplies: 0Last Post: 18th Feb 2022, 06:44 PM -
Where to purchase a weld-in 4L60E auto transmission sump plug
By Specialized29er in forum AUTO PARTS / Wanted, For Sale - HELPReplies: 10Last Post: 18th Mar 2018, 04:10 AM -
Washing machine pump as a coolant pump
By BobL in forum METALWORK GENERALReplies: 66Last Post: 9th Oct 2015, 09:25 PM -
Oil pump
By Michael G in forum METALWORK GENERALReplies: 2Last Post: 5th Oct 2013, 08:54 AM -
Pipe Vice-pipe bender identity and info please
By Log in forum METALWORK GENERALReplies: 18Last Post: 18th Apr 2012, 01:14 PM
