Results 1 to 15 of 26
22nd Feb 2022, 08:31 AM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Brand new tools that need repair before usage
We have probably all bought cheap new tools, and found them unusable in some way.
If they are from a local dealer, it is easy (possible?) to send them back for a refund/swap.
When they come from overseas, and there are language communication issues?
Or postage from Australia would cost more than you paid for the item?
You have to either throw the tool away, strip/repurpose, or use our skills+tools to fix the tool !!!
Here are a few recent examples;
1) Small Dial Indicator and base (China, $34)
Looks good for the price, huh? Indicator is OK unless you drop it too hard. Then it will read if you have the lever to the right, but not if the lever is to the left! The base was the actual problem. In the configuration shown, it works OK, but if you have the DI a bit further out from the base, it topples over.
I just thought that was the way it was (weak magnet on 20mm sq. base), until someone else looked at it and noticed the base wasn't flat, so it rocks around and only has a small contact area. Simple fix on the surface grinder:
which removed the bad non-flat linishing, and helps it stick to flat surfaces.
Still too weak to attach to your average machine casting, though
2) Quick Change Tool Holder (part of $470 order, but $140 of that was shipping).
One of the Vs was machined out of spec. I told them about it.
The shop told me to send a video showing the fault, and just to clamp it tighter.
My time was worth more than what would have been a drawn out fight,
so I opened it up a little on the mill (my first real milling job):
That got it to sit propetly on the Vs, but then meant the clamp doesn't grab it tightly enough to seat it well on the "Italian Style" (Dickson) QCTP block. But it varies between sides, as some of the clamping plates' cams are smaller than others.
That taught me never to buy any of those QCTHs again. I will make my own in future.
Does anyone have any similar "new tool repair" stories to share?
22nd Feb 2022, 09:50 AM #2Member: Blue and white apron brigade
Don't want to sound too rude but just looking at that dial indicator stand would make me suspicious as would the price.
I'd say you probably just got what you paid for?
22nd Feb 2022, 09:15 PM #3Diamond Member
- Aug 2019
- 1,196
22nd Feb 2022, 09:25 PM #4
23rd Feb 2022, 01:08 PM #5Member
- May 2012
- Dandenong
- 76
23rd Feb 2022, 01:48 PM #6Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
23rd Feb 2022, 02:50 PM #7Member: Blue and white apron brigade
23rd Feb 2022, 05:01 PM #8Member
- May 2012
- Dandenong
- 76
23rd Feb 2022, 07:17 PM #9Most Valued Member
What else would you expect from the Chinese!!!!!
Pity their products don't last as long as this Virus!!!
That's one of the reasons I try to buy better quality tools, you don't have to modify/repair them before use.
24th Feb 2022, 11:40 AM #10
The contact tip can be moved by a push with your fingers, and are supposed to be adjustable.
Sent from my 5007U using TapatalkUsing Tapatalk
24th Feb 2022, 04:47 PM #11.
- 6,459
Chinese not Israeli.
I wanted to replace the permanent magnet base fitted to a little Noga arm, with a switchable magnetic base. An industrial supplier in Padstow, NSW had a small Noga base for just over $50 which seemed reasonable for an Israeli product. (The supplier provided no information regarding the base's country of origin.) Had I known that it was Chinese AND that it's action was rougher than the two $15 Chinese bases I already owned, I would not have bought the ring in.
The base required a fair bit of fettling to render its action smooth. In contrast, the larger Noga base that I've owned for close to twenty years has always functioned flawlessly.
IMG_20201208_105725673.jpg IMG_20201207_101430193.jpg IMG_20201207_103228084.jpg IMG_20201207_095600293.jpg
I posted photos of the base on Instagram and received a response from Avi Widovski at Noga in Israel. Here is part of his reply to an email I sent '' All our products are made in Israel.
The magnets only (internal parts) are made in China. This is the only country who are producing the internal parts of the magnet only. We inspect/test the magnets and modify them. So far we did not receive any problems.
Will make sure that our local agent will call you shortly and replace the magnet if necessary."
The local agent did contact me and asked me to return the base for replacement. I chose to stick with the repaired base because how could I be assured that the replacement would be better.
I have purchased enough from China to have no great expectations, sometimes I'm pleasantly surprised, othertimes disappointed. Buying something Chinese at an Israeli price is something else.
24th Feb 2022, 10:45 PM #12Most Valued Member
- 2,672
Interesting Bob.
I’m assuming Noga were satisfied it was a genuine item and not a counterfeit?
25th Feb 2022, 02:04 AM #13.
- 6,459
25th Feb 2022, 08:13 PM #14Diamond Member
- Aug 2019
- 1,196
Yes, like most lever DIs, there is a little clutch in the arm, so that the lever+tip can be repositioned.
Parts 2 and 1 respectively in this:
The problem with my DI seems to be Part 7 not meshing on part 9. If the face is on the left of the lever, it works. If the face is on the right of the lever, 7 and 9 somehow fall out of alignment. Haven't made a clean enough space yet to carefully disassemble
25th Feb 2022, 08:52 PM #15Diamond Member
- Aug 2019
- 1,196
Cheap taps
Here is another example.
I have needed some BSP taps+dies for years.
There are some small sets around: https://www.lprtoolmakers.com.au/bsp...-carbon-steel/ that are priced reasonably, but looking closely at the web site image shows a big dag on one of the teeth:
That put me off. I'm guessing Aprica are made in India?
I'm guessing the web page designer isn't detail oriented.
I'm hoping they didn't photograph the best set they had
So, I bought a few cheap individual G series taps from China. And they have a similar fault.
Hard to see from my phone's camera:
but there are multiple burrs on the edge. Look like the flutes have been "ground" using a cold chisel.
I tried to wire brush them off. I tried to scribe them out. They are tough. I'm thinking I'll have to setup a lathe at 19tpi, and clean them up with a carbide thread insert. Except I only have 60° forms, not 55°.
Sigh.
Experiences About Frost Brand tools.T
By familyguy in forum METALWORK GENERALReplies: 17Last Post: 5th Aug 2018, 01:30 PM -
Plumb brand tools
By John T K in forum THE SMITHYReplies: 4Last Post: 18th Apr 2018, 06:03 PM -
Force-brand tools???
By TheOtherLeft in forum METALWORK GENERALReplies: 4Last Post: 15th Jun 2011, 10:49 PM -
Thread Repair tools
By TheOtherLeft in forum METALWORK GENERALReplies: 24Last Post: 11th Apr 2011, 06:11 PM
