Results 1 to 11 of 11
Thread: Scary welder
9th Feb 2022, 11:22 PM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Scary welder
This ancient 3 phase welder was donated to the Laidley Pioneer Village for display only, definitely not for use. I can't see a brand on it but there is a plaque that mentions to use Boss welding rods. The really interesting part is the warnings on top of the cabinet. Different times.
9th Feb 2022, 11:53 PM #2Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
For laughs, If that were mine I'd put it in the corner of the shed, clearly unplugged but with an electric fence energiser in the case
10th Feb 2022, 12:11 AM #3
By the shape and apparent size it could be either an old Hobart or a EMF unit. Both had those rounded corner cabinets reminiscent of the fridges of that era.
Three phase and up to 350 amps,just the thing for running semi iron 5mm electrodes.
Ours had stops which were pulled out or pushed in to set amperage.
This one looks to have knife switches to throw. The bakelite insulated switch handles ( thats what ours had) did not seem to stand up very well to being smacked with heavy steel beams.
What sooks they are today complaining about a little boot every now and then. Bloody young fellers -keeps em awake.
It was only only a touch over 80 volts- never more than 115 Volts. Bit of a nuisance in a hot humid Brisbane summer. You only got issued with a single set of gloves at a time and they got loaded with perspiration. Much nicer to use in winter when you could put your pie or chiko roll on top to warm it for lunch.
10th Feb 2022, 12:19 AM #4China
- Dec 2005
- South Australia
- 1,658
My mate has one it must be over 40 years old he taught to weld with it he uses it all the as his shed welder.
11th Feb 2022, 12:39 AM #5Most Valued Member
The old "Pie Warmers" were magic to use if they had the High Frequency switch.
Used to use mine with a TIG set up and later got the AC/DC converter for welding stainless.
Use to LOVE running it especially when the young blokes would have their C RAP music going, the HF would cause the radio to play static.
Them was the days.
12th Feb 2022, 07:25 PM #6Senior Member
- Dec 2009
- 327
Only a little-y, but interesting. Was at the 'Junk Yard' of Londonderry (NSW) a few years ago, gone now.
regs,
AO'C'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
12th Feb 2022, 07:28 PM #7Senior Member
- Dec 2009
- 327
For those afraid of such units, what do they think of the stiff bit of wire out the end of the operator's handle??
12th Feb 2022, 07:41 PM #8
Way back in the distant past I remember the steel conduit glowing red when the operator was doing some welding !Best Regards:
13th Feb 2022, 05:20 PM #9Senior Member
- 112
It's hard to tell from the picture, but it looks like an old "Samson" brand welder. I had one offered to me for sale S/H in the 1960s, but bought an EMF Transarc 200 instead from the seller. The Samson was 415v only, so the dual voltage EMF prevailed. The core construction was interesting as the laminations were arranged to provide cooling fins. Current control was a shunt plate (uncalibrated) held in position by an eccentric cam lever. The core was bolted in a wooden frame. The unit appeared crude, but it performed brilliantly when I tried it.
Chas.
20th Feb 2022, 02:45 PM #10
20th Feb 2022, 03:38 PM #11Senior Member
- Apr 2021
- 212
Novice welder - cheap MIG welder - 3mm RHS Butt joints
By mote in forum WELDINGReplies: 14Last Post: 26th Mar 2021, 12:09 PM -
QUEENSLAND Cig welder transarc tradesman HD (stick/arc welder) 3phase
By dkaoffroad in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 8th Jun 2013, 10:45 AM -
Which mig welder??
By DR ZOIDBERG in forum WELDINGReplies: 2Last Post: 17th Aug 2011, 03:15 PM -
Mig welder
By China in forum METALWORK GENERALReplies: 0Last Post: 22nd Dec 2009, 02:33 AM -
Mig Welder
By garfield in forum METALWORK GENERALReplies: 18Last Post: 4th Nov 2008, 09:10 PM
