Results 1 to 5 of 5
Thread: How to remove chuck
27th Jan 2022, 12:56 AM #1Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 314
How to remove chuck
A friend has sent me a video of an old machine he's bought in the hope I'd know how to remove the chuck. He's bringing a head over for me to look at but before I start pulling it apart I thought someone might have an idea of where to start. It's only got an 8mm chuck & he wants to go bigger. I couldn't load the video so this photo is all you'll get.
F K Pollard & Co were the manufacturers & I think this is the setup. Pollard 9dfx drill.jpgLast edited by Snapey; 27th Jan 2022 at 01:12 AM. Reason: Video wouldn't load.
27th Jan 2022, 02:22 AM #2
Hi Snapey,
That drill was only intended to handle small drills and the chuck was fitted to suit that application ! The chuck is on a JT1 taper and really shouldn't be changed. I would leave it as is.Best Regards:
27th Jan 2022, 06:32 AM #3Philomath in training
A set of wedges are needed I think for a job this delicate. I vaguely recall making a set of JT1 wedges in one of my videos because they are not very common. However, looking at the lowest speed of 2700rpm, that is the speed you would run 1/8" Steel, and around the speed you would run 3/8" Al. If the chuck has an 8mm capacity at the moment, there is no point in putting a bigger one on as bits greater than 8mm will be running overspeed with all the issues that will generate.
27th Jan 2022, 06:47 AM #4China
- Dec 2005
- South Australia
- 1,658
I second What Baron J. said
27th Jan 2022, 08:19 AM #5Senior Member
- May 2019
- 77
- 314
Many thanks for the replies gents. You confirmed my thoughts of how the chuck is fixed although a screw in type chuck also crossed my mind. Luckily my engineering skills out weigh my computer skills so sorting the drill will be much easier than downloading a video.
Just to fill you in on the reason for getting the drill working is that my mate has been using the rather large drill table just as a work bench but because the drill is there he thought about using it. He doesn't have a computer so I found the above example on Google. It is similar but the heads do look smaller than what he has although totally useless as a general purpose drill.
I'll have a look at it but the too hard basket seems obvious to me.
How do you remove the #2Morse Taper Shank From A Jacobs Drill Chuck ?
By RoyG in forum METALWORK GENERALReplies: 13Last Post: 15th Apr 2016, 10:40 PM -
Jacobs 14N jacobs chuck how remove the morse taper arbor
By woodfast in forum METALWORK GENERALReplies: 7Last Post: 28th Jul 2013, 02:53 PM -
how to remove the chuck on a 260g
By welder in forum THE HERCUS AREAReplies: 4Last Post: 25th Jul 2011, 10:41 AM -
How do I remove old grease
By Bidgee in forum METALWORK GENERALReplies: 6Last Post: 14th Apr 2010, 10:00 AM
