Results 1 to 10 of 10
Thread: Hedge Trimmer Mod
25th Jan 2022, 03:21 PM #1Diamond Member
- Jun 2010
- Canberra
- 1,322
Hedge Trimmer Mod
I've just taken delivery of this hedge trimmer:
In this video (at this time point) https://youtu.be/MTmvxEMS6Dk?t=620 the guy points out a particularly poor aspect of a similar hedger's design.
Specifically, there's no kind of bearing for the drive fork pivot, meaning the hole, bolt or both are likely to get flogged out pretty quickly:
Given there isn't a heap of material to work with, my first thought is maybe a bronze sleeve pressed into an enlarged hole the driven part with a grease nipple added to the side, and then some kind of sleeve for the bolt? Any suggestions welcomed.
25th Jan 2022, 03:55 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
If I were doing it, I’d torque the fastener to yield with a lock nut and run it. That joint is designed as a clamp not a point of articulation. If you have movement yes it will flog out, correct torque on the fastener means the joint is clamped as it should be with no movement. That’s why it’s designed without a bush. If I was looking at reengineering it I’d be looking to add more clamping surface to both parts of the joint so a second bolt could be fitted.
25th Jan 2022, 04:02 PM #3Diamond Member
- Jun 2010
- Canberra
- 1,322
25th Jan 2022, 04:53 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
Id consider straight up reengineering it, I dont really think there's anything you can do with such small surfaces to get it to really last? Some kind of hard pin and bronze bush will do for a while but not forever.
25th Jan 2022, 05:12 PM #5Most Valued Member
- Mar 2011
- 1,555
25th Jan 2022, 05:41 PM #6Diamond Member
- Jun 2010
- Canberra
- 1,322
While I haven't fired it up yet, I'm assuming it'll behave like this:
https://youtu.be/MTmvxEMS6Dk?t=131
As you suggest, a larger block to take a decent sized bearing may be the go.
25th Jan 2022, 05:56 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,229
Id just replace the set screw with a shoulder bolt (https://www.boltandnut.com.au/12mm-x...gaAivlEALw_wcB) and run it until its a problem.
Then remake the bracket to suit a self aligning bearing. I wouldn't mind betting it will last a long time before it needs fixing.
25th Jan 2022, 08:03 PM #8Senior Member
- Jul 2007
- 332
My 2 cents worth, as snapatap says a shoulder bolt, but I would put a grease nipple and drill / bore the connecting path to get lube to where it does the most use in the block, similar to earthmoving equipment, then 1/2 spherical washers between the conrod and yolk to account for whatever movement remains. If you were feeling like doing a full job, then bore out the drive block and bush it for the shoulder bolt, but doubt this would be necessary if greased. Alan.
25th Jan 2022, 10:08 PM #9Diamond Member
- Jun 2010
- Canberra
- 1,322
We're pretty desperate for the machine to get going, as there's a heap of hedging to be done, so I've added a grease nipple, and hunted high a low for a high tensile M12 bolt with an unthreaded section that would span the drive block, but couldn't find anything, and left it too late for the fastener shop, so the original fully-threaded bolt has gone back in. Not sure if the grease will do anything, particularly as there's nothing retaining it - the spherical washer suggestion should address that.
I hope to have it mounted on the tractor tomorrow and I'll see how it holds up.
30th Jan 2022, 04:35 PM #10
Plain Pin
If it's supported on both sides of that brazed-on block (ie; the 'piston strap' engages on both sides of the block on the moving part of the scissor, then a plain, hard pin with a couple of washers and split-pins (or R-clips) would be cheap and way better than a set-screw.
It could also come out easily for the frequent application of heavy grease or a suitable tough lubricant.
When it starts to get sloppy, you could ream-out all three holes in-line, press in three plain bearings and use another, slightly-smaller perhaps, plain pin.
Stihl trimmer bearing
By russ57 in forum METALWORK GENERALReplies: 6Last Post: 6th Sep 2020, 01:38 PM
