Results 1 to 6 of 6
Thread: Polishing inside tube
21st Jan 2022, 08:11 PM #1New Member
- Jan 2022
- Netherlands
- 3
Hi all,
I want to polish the inside of some SS tubes using a sand flapper wheel.
To properly reach inside the tubes I would need an extension for the
sanding wheel, however I can't seem to find any suitable parts online.
There are some drill bit extensions available, like this: https://tinyurl.com/2p8knz5a .
They are mostly 300mm long and cost approx. 10 bucks so that would be OK, except they
have a female hex opening at the end while the sanding wheels are usually
mounted on a round rod, which means that when mounted in the extension
bit they would not be centered.
Does anyone happen to know of a simple way or other part which could
help me solve this problem? Thanks in advance.
21st Jan 2022, 08:37 PM #2Novice
- May 2018
- Brisbane
- 12
I do that with a length of dowel of suitable dimensions. Cut a slit in one end fit a strip of wet and dry of suitable grit wrap a bit of tie wire round the end of the dowel to hold it together and chuck it and polish away.
21st Jan 2022, 09:47 PM #3Most Valued Member
- 2,651
I do similar with dowel or just a piece of steel rod.
I’ve never had to tie the end - as long as you put center of the piece of emery cloth or sandpaper in the slot, wrap it around and keep it turning while you remove it it stays wrapped tightly into the slot.
Scotchbrite works well like this too.
21st Jan 2022, 09:48 PM #4Member: Blue and white apron brigade
- 7,182
What diameter are we talking about?
RE: Using Dowel.
I did this with some Al tubing that was ~40 mm in diameter and up to 400mm long (yes it was a wind chime ) using a length of 25mm dowel onto which I turned a reduced (13mm) shank . Instead of using a slot I drilled about a dozen 10 mm holes at right angles to each other and rolled up some steel wool into 150mm long tapered cylinders and poked these through the holes so there were tapered hanks of steel wool hanging out each side of the holes. I then put the reduced shank into a floor standing DP and did the obvious thing with the tubes with the dowel at about 100 rpm. I made up three dowels - one with medium steel wool, one with super fine wool, and one with cotton rags coated in some buffing polish - came up a treat.
21st Jan 2022, 10:52 PM #5New Member
- Jan 2022
- Netherlands
- 3
Thanks for the replies guys, I think I might try the dowel method, it sounds like it
might be good enough for what I need done.
@BobL: the tubes in this case are in the 25-100 mm diameter range, length about 200 mm.
22nd Jan 2022, 01:16 AM #6
Hi uj33,
Welcome to the MetalWork Forums
We have great bunch here very helpful and supportive of one another. You will find many like minded folk here, perhaps with same interests as you.
If you explore our pages you will find bits and pieces of interesting things all over the place.
Go to the FORUM box at top LH corner and click on it.
A drop down menu appears and you can select Forum Home at the top of the drop down menu list. Scan down the pages to look at what we have.
Please make an effort to read the Terms of Use -our Rules - pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member.
Not having read the the TOUs won't be of help if a rule is infringed.
Sometimes the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
Its anti spam thing.
There are all sorts of forums that might be parallel with your interests, found as described above.
If any questions contact me via PM and I'll try to help you.
What's going on inside a 3-point bore mic
By elanjacobs in forum METALWORK GENERALReplies: 6Last Post: 2nd Jul 2019, 02:56 AM -
Basic level question: How to expand the inside of a brass tube?
By Nyah in forum METALWORK GENERALReplies: 5Last Post: 11th Feb 2014, 06:37 PM -
Increasing inside diameter of brass tube
By rrjtedge in forum METALWORK GENERALReplies: 7Last Post: 19th Nov 2013, 06:21 PM -
What's inside a Biax (IV)?
By Michael G in forum METALWORK GENERALReplies: 17Last Post: 27th Apr 2013, 09:01 AM -
SOLD: Starrett Inside Micrometer
By Pat in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 25th Mar 2013, 01:20 AM
