Results 1 to 15 of 22
Thread: Single point thread cutting
18th Jan 2022, 07:01 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Sorry every one about a repeat topic.
At work I mainly do maintenance work.
We have a pretty smik little lathe. I have been trying to cut some threads but it's been a while.
Off setting the compound to 29.5 deghas not been working for me . Ends up looking like a buttresse thread.I use HSS. Does any one use the plunge or advance the compound method for thread cutting?
The threads are to support vechal development . For suspension dynos
I'm trying to make a 27mm 2 pitch to 1" unf thread adaptor. In mild steel.
18th Jan 2022, 07:28 PM #2Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Try setting at 60 or 60.5 degrees on the scale, that will give you half of the tool angle (30 degrees approx) from the straight in position.
18th Jan 2022, 07:31 PM #3Most Valued Member
- Oct 2010
- 1,910
18th Jan 2022, 07:35 PM #4Most Valued Member
- Oct 2010
- 1,910
Advance coupound
If I set the coupound at 0 deg. How much to I have to wind it regardinging to depth of cut and for how long. I seem to remember 2 in 1 across.
18th Jan 2022, 07:45 PM #5Philomath in training
18th Jan 2022, 08:02 PM #6
I agree with just plunging in and using the top slide dial for the depth of cut ! A caveat though I gave up on trying to grind accurate HSS tools to get the thread form correct, so on advice resorted to pre shaped carbide insert tooling, which I now use for both metric and imperial threads.
Forget about setting compound angles, just make sure that the tool is dead square to the work and plunge in. Yes I do understand why setting the compound at an angle is recommended, particularly for buttress, acme and other large threads.Best Regards:
18th Jan 2022, 08:31 PM #7Philomath in training
I don't even bother offsetting for larger threads - I've done buttress and ACME using plunge cutting. I leave the compound slide for syncronising the thread with the feed if I have to (as per the video where I battle the worms of doom), and feed with the cross slide.
18th Jan 2022, 10:00 PM #8
I agree, Just 90 degree plunge cut as said.
Sent from my 5007U using TapatalkUsing Tapatalk
19th Jan 2022, 10:01 AM #9I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Like most others here it seems, I've never bothered rotating the compound and just plunge with the cross slide alone.
However, if you did want to do the rotated compound method, Techo1 will probably be correct.
The reason for this confusion that arises at times is some lathes mark zero degrees on the compound with the compound perpendicular (at right angles) to spindle axis, others mark zero degrees with the compound parallel to the spindle axis. The Asian machines seem to often do the second, and if your machine is an AL960b the pictures on H&F website show that it definitely does the second.
If zero is with compound perpendicular, 30 degrees (ish) is correct, if zero is with compound parallel, 60 degrees (ish) is needed.
The easiest way to sanity check yourself which way round you need to be is that the direction of compound movement must be aligned with the trailing flank of the desired thread.
19th Jan 2022, 10:03 AM #10Member
- Oct 2017
- Lismore, NSW
- 58
Azzrock,
Keep trying the offset method of screw cutting as it is the best way to cut vee threads in MHO.
You are correct to offset the compound rest by 29.5˚ for 60˚ included angle threads. Half a degree less than half the included angle is the "standard".
The tool (if HSS) must be ground to the included angle of the thread, have a small nose radius achieved by honing. Then grind a rake angle of approx. 15˚ so that the leading edge of the tool is the only edge of the tool in contact with the work. Most importantly, set the tool at 90˚ to the work axis.
Zero both the dials on the compound slide & the cross slide. The depth of the cut is achieved by advancing the compound rest ONLY. The cross feed is used to withdraw the tool from the cut & must be returned to zero prior to the next cut.
Depth of cut for metric threads is found by; Depth = 0.6134 x thread pitch x 1.1434. This is the amount that the compound rest is advanced to achieve the whole depth of the thread. Variation to this calculated size may be required to suit the mating thread.
If imperial Depth 55˚threads = 0.6403 x 1/tpi x 1.1174
OFFSET.jpg Direction of tool movement.
Hope that this helps,
Regards,
Don.
19th Jan 2022, 10:14 AM #11Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
After adjusting the compound slide angle, are you setting up the tool bit accurately, with a screwcutting gauge?
https://www.micro-machine-shop.com/h...l_pulley_6.jpg
19th Jan 2022, 10:27 AM #12Member
- Oct 2017
- Lismore, NSW
- 58
Nadroj,
Yes, a screwcutting gauge must always be used to set the tool at 90˚ to the work axis.
However, as the tool has a rake ground onto it, only the leading edge of the tool is set to the gauge when using the offset method.
Regards,
Don.
19th Jan 2022, 05:12 PM #13Most Valued Member
- Oct 2010
- 1,910
[QUOTE=Don@2480;1993608]Azzrock,
Thanks Don good discriptin.
19th Jan 2022, 05:18 PM #14Most Valued Member
- Oct 2010
- 1,910
Thanks everyone. I had a success today after a few set backs.
I was using a thread form gauge to set up.
I stuffed up a few pieces when I tried to cut the second unf thread. I tried using the thread indexing dial instead of leaving the half nuts engaged.
I useded the plunge with compound at 0 deg. Ended up with a good thread.
Thanks Aaron
19th Jan 2022, 05:27 PM #15Most Valued Member
- Oct 2010
- 1,910
Thanks. Lathe is similar to this.
https://www.machineryhouse.com.au/L191D
Another single point threading question
By simonl in forum METALWORK GENERALReplies: 11Last Post: 30th Nov 2016, 10:34 AM -
A bit of single point threading
By Michael G in forum METALWORK GENERALReplies: 24Last Post: 21st Nov 2016, 10:34 PM -
Single point seeder ideas please
By KBs PensNmore in forum METALWORK GENERALReplies: 19Last Post: 30th Sep 2015, 11:08 PM -
Hercus 260 Metric - Help with Single Point Threading
By ventureoverland in forum THE HERCUS AREAReplies: 3Last Post: 19th Sep 2014, 11:48 PM -
Thread wobble - single point cutitng of small diameter threads
By variant22 in forum METALWORK GENERALReplies: 9Last Post: 18th Jun 2014, 02:23 PM
