Results 16 to 30 of 44
  1. #16
    Apr 2019
    Adelaide
    596
    So my motor appears to be very over-powered. Does anybody see an issue with this?
    EDIT:
    If I understand it correctly (and I probably don't), an 850W rating is the power the motor can output for ever without damage. The motor will not necessarily be running at 850W all the time? Free running my DIY scraper would presumably see it use a far lower amount of power as there is no load. If I pushed the blade into the workpiece with everything I had it was exceed 850W?
  2. #17
    Feb 2013
    Laidley, SE Qld
    1,039
    I have this repurposed reciprocating saw - its not my work - which weighs just under 3kg.
    Story time. I forget who the donor was, this Bunix as it was referred to was donated to one of the sadly missed Phil Fehring's (Machtool) scraping classes. All the names went into a hat, I was the lucky winner.
  3. #18
    Oct 2007
    Alexandra Vic
    69
    654
    Quote Originally Posted by Mk1_Oz View Post
    The motor power rating is the maximum power level the the motor can be operated at long term at whatever duty cycle the manufacturer specifies. Off load the motor alone would be in the 85 to 100W region, but in usable form with drive mechanism losses etc would be higher. Once upon a time power ratings were specced for mechanical output power, nowdays it is a mixture of mechanical power output and electrical power input depending on manufacturer, application, and price point.
    Power rating is based on wire sizes, number of turns in the windings, and the units ability to dissipate heat. Overload the motor, it tries to draw more current to provide the power output being demanded, it generates more heat that may not be dissipated, overheats and burns out. There is no issue with operating the motor below rated power provided that you meet duty cycle requirements, the motor basically runs with less current and heat buildup.
  4. #19
    Oct 2008
    N.W.Tasmania
    1,407
    Of course all things being equal, the more powerful the motor, the heavier it will be, and the more expensive to make because it uses more material. With a Biax type scraper, it is advantageous to have a certain mass, to resist the push back from the scraper blade on the workpiece. The more mass, the less reaction felt by the operator. A compromise has to be reached, so that the tool is not so heavy in the hands of the operator that it tires him (or her) prematurely, or perhaps a design featuring a reciprocating balancing mass moving 180º out of phase with the blade to keep the vibration level in a reasonable comfort zone. A spring balancer as referred to by Stu will enable you to have more mass without having to carry all the load on your own.
    I, like nearly everyone else would love to have a cheaper alternative to a biax but sadly the demand volumes are not there to support alternative suppliers it would seem.
  5. #20
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Given that most members here only ever use a scraper for a short period at a time (a few weeks), and that quite a few of us have them, I wonder if we can do a "loan scheme" or "rent scheme" on the forum?
    I have a BIAX flaker that I rarely use and certainly would be happy to make it available to such a scheme. My scraper is in use a bit more frequently (I hate and mostly fail in filing and can often do a nicer job scraping), so there are a few reservations about that one....
    Ideas? Concerns? Solutions?
    Cheers, Joe
  6. #21
    Jul 2010
    9,088
    Mine is 840W, I doubt 10W will make much difference
    One thing I should add here. When I first made mine I know I said a few times that "I can remove as much metal per cycle by hand as I can with the bunix"or something along those lines. That was when I had it set to a pretty short stroke. When I finally upped the stroke length that statement because BS but may not have been corrected everywhere, so if someone comes across that please disregard.
    I'm not so sure about the mass reaction theory. Yes it applies to any moving mass in the tool, but surely ANY work done by the tool does goes into the operator? The best mass can do is average that out over time. So yeah maybe a bit, but given the amount of work being done, the number of strokes and the at best 50% difference in mass.....twice "not much" still isnt a great deal(or is it not as simple as "twice"?).
  7. #22
    Jul 2006
    Athelstone, SA 5076
    4,258
    Are Biax scrapers available for hire from any where in Aust?
  8. #23
    Nov 2017
    Geelong, Australia
    57
    2,673
    Its a great idea Joe, but unfortunately I can see how it could go pear-shaped if it were a general loan/hire thing.
    Given that they are hideously expensive to replace new, and not readily available used (and still relatively expensive), my main concern would be what happens if one gets lost/damaged or smokes a motor etc.
    In my case as a potential loanee, I'd be hesitant to take on the responsibility of borrowing a genuine Biax knowing that if something went wrong I could potentially be up for a few thousand to make it right. Some might not have that concern and be happy to take the "all care - no responsibility" approach, but personally I cant.
  9. #24
    Jul 2006
    Athelstone, SA 5076
    4,258
    would insurance be an answer?
  10. #25
    Aug 2010
    72
    3,105
    I'd be extremely surprised if any were for hire somewhere in Australia. In fact, I suspect the total number of Biaxes in Australia would be less than 30 - and probably more than half in possession of members of this forum - lol....
    The issue of repair/replacement on failure or loss is the biggest concern, of course.
    Anyone got any ideas of how hire services deal with that? What sort of insurance would be available?
    It just seems a pity that we have these expensive and difficult to get tools for occasional use and couldn't find a way to share them....
    When I loaned a member my magnetic drill (replacement way over $1000), to drill 200 holes in 50mm steel plate, I did have some concerns about life-span reduction, but the machine never even got warm drilling the holes - unlike to operator.... and I was glad I could share it.
    Cheers, Joe
  11. #26
    Nov 2017
    Geelong, Australia
    57
    2,673
    There’s definitely hire insurance available Joe, but I don’t have any idea of costs or conditions.
    That could be a reasonable solution from my perspective.
    Even if the excess was say $500 it would bring the financial risk for both parties to a reasonable level IMO.
    The other thought I had was what about some sort of group Bunax project. Decide on a cheap donor tool and build a bunch of them.
  12. #27
    Jul 2006
    Athelstone, SA 5076
    4,258
    what length stroke did you end up with
  13. #28
    Jul 2010
    9,088
    Tricky
    Having just reread my first post in the thread I linked, I had forgotten I even had that idea about "steps", what I actually built uses a couple of grub screws and a tee slot to give infinitely adjustable stroke length.
    A quick check has it adjustable between 0-11mm.
    It was set on 4mm but I'm pretty sure that's more finished.(its been awhile)
    Most likely just maxed it out when roughing.
    Last edited by Stustoys; 18th Jan 2022 at 02:55 PM. Reason: indefinitely adjustable lol
  14. #29
    Aug 2011
    4,779
    Hi all,
    I'm in need of a power scraper but I just cannot justify the expense of a Biax machine.
    I would be keen on a group online project to build a Metalwork forum project copy!
    There a few members on this forum who have successfully made these machines from a cheaper donor machine. I'd be keen to do the same.
    We could start a joint project thread.
    Sent from a galaxy far far away
  15. #30
    6,480
    Some time ago either Lidl or might have been Aldi, "Powerfix" brand anyway, sold an electric scraper intended for use on wood or wallpaper, complete with several chisels. One intended for wood, about 3/4" inch wide is an ideal candidate for modification as a metal scraper. The machine has a variable speed control and will reduce the speed to almost a stop. I modified mine with a carbide insert when I made my Brooks grinder ! Once you got used to using it, it worked well. Without going and digging it out the motor was about 250 watts.
    I've seen these same electric chisels on Banggood and Ali express for the same money that I originally paid which was £29 or £30. I've since used the tool for removing grout from between floor tiles prior to re-grouting them.
  1. WTB Power Scraper biax, renz, etc.
    By qb6sagr in forum WANTED TO BUY
    Last Post: 2nd May 2021, 12:14 AM
  2. Biax scraper motor repair help.
    By lamestllama in forum ELECTRICALS
    Last Post: 4th Jun 2018, 10:01 PM
  3. Scraper Value
    Last Post: 5th Mar 2018, 11:07 AM
  4. Problem with Biax scraper after rewinding
    By marcuschrist in forum METALWORK GENERAL
    Last Post: 23rd Aug 2017, 09:55 PM
  5. Biax anyone?
    Last Post: 29th Oct 2015, 04:37 PM
