Results 16 to 21 of 21
11th Jan 2022, 02:01 PM #16Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
What is the inside width of the channel? I have a few different types or riveters for difficult jobs like this.
11th Jan 2022, 03:12 PM #17Most Valued Member
- 2,671
Just a thought, but assuming there is a standard length above the rivet head, if you get the longest grip length rivets you can find then is the mandrel longer overall?
If so, taking the mandrel out of a longer rivet and using it in a shorter one might be a possibility?
Ok - likely not the first choice if you’re looking at ~100 rivets, but….
11th Jan 2022, 03:23 PM #18
11th Jan 2022, 06:51 PM #19Member
- May 2012
- Dandenong
- 76
12th Jan 2022, 10:33 AM #20
Thank you for the application - it now make complete sense to this old brain and I wonder why I did not see it before. I can see Gary (old boss) applying the grinder to his spanners and wonder if he would have tried modifying the setting tool to fit in the channel (cringe)..
Did the rivets have aluminium mandrels? .. I have had a few ali mandrel rivets that break the mandrel in the wrong spot so I have to drill them out and start again... blamed my setting tool for damaging the mandrel as it was always at the end of the jaw mark, but thinking about it, that is where the max stress is, hence the necking..
Re supply, There seems to be a mentality in our retailers that if it does not sell in a few weeks, they do not stock it. Every so often I have been surprised to find an interesting item in one of the large hardware stores (Think clips, rubber mouldings, 5/32 (4mm) masonry screws in 50mm length) and then to come back a couple of months later with an application and find they are no longer available. These are huge stores, no lack of space. As a teenager in the Adelaide Hills the local hardware (little store built across the local creek) had a huge range in comparison and I bought taps and dies (Yes only whitworh), boxes of metal thread screws in model making sizes, occasionally large drills without reduced shanks, I drooled over morse taper shank drills on the shelf. Our food stores have done the same thing reducing the range of items... look at the lack of variety of flour compared to a few years ago. (Pops tomatoe sauce is another to see if you can find) I am told it is about efficiency. It really is a delight when I find a retailer, bricks and mortar or online, that has a wider range of items.
Hope your project lasts well and long so, as my Dad would have said, "it is not your problem again"Last edited by HavinaGo; 12th Jan 2022 at 10:34 AM. Reason: removed quoted picture
cheers
David
A society grows great when old men plant trees whose shade they’ll never sit in. (Greek proverb)
12th Jan 2022, 01:02 PM #21
HavinaGo,
Cringe as you may, but in the interests of honesty, I did indeed modify one nozzle so that it would fit in the channel, which it did, but still left me short, however I drew the line at reshaping the nose as it would have left little material thickness at the sides.
The rivets are Ali with steel mandrels. I balk at using the term "Steel" because like you, I have had too many rivets end up with varying lengths of mandrel sticking out after snapping off where they shouldn't, so I think pure Chinesium is what they really are.
Pop rivets of 40 years ago did not seem to suffer the same shortcoming.
What you said about turnover dictating what is stocked is spot on, at least at the only hardware store left in the region where I live. Twenty years ago there were 5, but the big green warehouse came in and wiped them all out one by one.
I was talking to an employee of said warehouse and he told me that 90% or the stock on the shelves is not the retailers, but the wholesalers, who rent the shelf space and decide what gets on the shelves & what doesn't. I suspect it might be a little more complicated than that, but the basics are correct.
"Efficiency" is what they say, "Profits" is what they mean.
Thanks for your good wishes. I am at that age where it could go either way, so without willing my remaining life away, I hope it will not be my problem again
Bearing removal from a blind hole !
By BaronJ in forum TIPS, TRICKS & HOW TO'SReplies: 9Last Post: 11th Apr 2021, 07:29 PM -
Removing blind rolled pin
By KBs PensNmore in forum METALWORK GENERALReplies: 7Last Post: 15th Jan 2019, 09:24 PM -
Cutting an internal blind keyway on lathe
By .RC. in forum METALWORK PROJECTSReplies: 6Last Post: 25th Sep 2016, 01:14 PM -
Removing bearings from blind holes
By jhovel in forum METALWORK GENERALReplies: 6Last Post: 4th Apr 2016, 01:18 PM -
Blind Hole Spotters
By colbra in forum METALWORK GENERALReplies: 8Last Post: 25th Aug 2012, 08:21 PM
