Results 1 to 15 of 16
1st Jan 2022, 09:53 PM #1
NUT, hex., S., %-24NF-2 (steering arm stud).
Hi
I need to make some special 3/8 UNF 'deep' nuts for a Jeep project. The steering knuckle studs require long or deep nuts , around .5" in length.
The originals are corroded and I am guessing are probably a grade 5 nut in todays terminology.
I could probably use hex bar and make them but what grade of steel is suitable and it needs to be soft enough to be hand tapped ?
1st Jan 2022, 10:16 PM #2Gear expert in training
- 34
- 1,080
1045 would probably do, 4140 if you want to go nuts
1st Jan 2022, 10:19 PM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,229
These might be suitable
https://www.unitedfasteners.com.au/p...t#product-list
1st Jan 2022, 11:03 PM #4
Yep thanks
Yes I did find those last night - But I am not sure about the 'bright' grade . Do they mean mild steel I wonder. I guess I could ask them.
Would 303 grade stainless be an option ? Problem is finding it in hex bar.
I did think of 1045 , it probably would be OK but not easy to find in hex bar around here, I might ask at the machine shop in town.
Found these: https://nhtb.com.au/ND%2038F%20BRT.html
2nd Jan 2022, 04:13 PM #5
Do you mean 5" long Morrisman ? Or .5" -half inch?
If ss is alright to use, what about two stainless steel joiner nuts tacked together?
I have seen them in smaller sizes ,so assume you can get larger ones.
Just thinking out of the box. Where is the force on these nuts .In tension, compressive or lateral?
2nd Jan 2022, 07:49 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
They’re available off the shelf in 304 stainless if you googlefu 3/8 UNF Stainless coupling nut. Standard size seems to be 1 1/8” long.
Personally I would not put stainless in the suspension of a motor vehicle
2nd Jan 2022, 08:05 PM #7Most Valued Member
- 70
- 1,514
2nd Jan 2022, 08:26 PM #8Most Valued Member
2nd Jan 2022, 09:53 PM #9Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
In a way the grade of nut used isn't important.
The forces on the steering knuckle are transmitted to the suspension via the tapered shank and socket, there are no forces on the nut itself.
The main jobs of the nut are to pull the taper up tight in the socket and to act as a safety should the taper come loose in the socket.
From what I see of hex steel its mainly leaded steel.
Assuming you do want to go with say 1045, for the small quantity you need it will probably be easiest to mill your own from round.
If it were me I would be making the hex first and then doing the tapping.
2nd Jan 2022, 10:48 PM #10
Good
They will do the job.
The image shows the steering setup . The pre-load spindle setup using the shims is a critical adjustment on these old Jeeps , if not set up correctly the steering can go into a uncontrollable situation known as the 'death wobbles' which is when a wild side to side oscillation of the front wheels can occur. Driving over a railway crossing at speed can set it off , some people fit a steering damper but that isn't a ideal solution.
3rd Jan 2022, 08:19 AM #11Most Valued Member
3rd Jan 2022, 11:58 AM #12
Getting further out of the box! Why does it have to be a hex section? Would a round bar drilled and tapped and with two parallel turning flats suffice?
If no mill, Hacksaw and file or tack a hex nut (drilled for clearance) to lock or turn it.
Never give in or give up.
3rd Jan 2022, 12:03 PM #13
[QUOTE=bob ward;1993051]
From what I see of hex steel its mainly leaded steel. [QUOTE]
Best NOT to weld on leaded steel then. My bad!
4th Jan 2022, 12:59 AM #14
MOre
The allfast mob in N.Z.... turns out they are a wholesaler to the trade and they are not interested in a backyard hobby person.
I think I can source some 1045 from ABC metals in Hallam, they are a short walk from the train station , I have a MYKI card somewhere ! Apparently Stainsfied-Smith has closed which is a real shame because they had in stock just about anything you needed. The present situation means I'm not sure about travelling anywhere right now , the COVID cases have gone nuts in Victoria .
4th Jan 2022, 05:12 AM #15Senior Member
- Apr 2007
- Newcastle
- 229
Surely you aren't the first to encounter this problem, what have others done?
Steering Wheel Restoration
By Goggomobile in forum AUTO RESTORATIONReplies: 8Last Post: 30th Aug 2021, 12:32 AM -
WTB - Manual steering box
By OxxAndBert in forum AUTO PARTS / Wanted, For Sale - HELPReplies: 1Last Post: 14th Nov 2019, 09:38 PM -
Steering gear cutters?
By Ash240 in forum METALWORK GENERALReplies: 6Last Post: 24th May 2012, 09:53 AM -
Self-steering trailers
By joe greiner in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 12th Apr 2010, 06:06 PM -
4 Stud Hub
By Teardrop.Camper in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 8th Jan 2009, 01:47 AM
