Results 1 to 5 of 5
Thread: Hardness files
31st Dec 2021, 12:55 PM #1Golden Member
- May 2020
- Willowbank QLD
- 517
Hardness files
Hello all.
I have seen a few sets of hardness files for sale. As I understand it you essentially you use different files in the set and whichever one marks the surface is the approximate hardness. Does anyone here have experience with these and are the worth it.
Thanks Steve
31st Dec 2021, 02:32 PM #2Gear expert in training
- 34
- 1,075
No experience, but I imagine they would only really be useful if you do a lot of work with mystery metal or repair jobs.
31st Dec 2021, 02:56 PM #3
I have a cheap set and use them to check hardness in knife blade materials.
I was given an electric furnace and will use that to harden the blades and for me, thats where the hardness checking function is utilized.
They are an approximate method of checking the hardness.
31st Dec 2021, 05:39 PM #4Member: Blue and white apron brigade
- 7,182
I have used a cheap set and found them a bit frustrating so I bought an expensive Japanese set (Tsubosan) but they are not that much better.
The Tsubosans cost $70 but I see they are over $100 these days.
The way to use them is as follows - assume set is marked A for the hardest and F for softest
Starting with the hardest file (lets call that one "A") and see if it marks the piece of interest
Then use the next hardest file (B) to see if it marks the work.
etc
When you find a file (lets say that's file E) that doesn't marks the surface this means the hardness is between D and E
Given the files are 5 units of "Rockwell Hardness C" (HRC) apart, then the actual hardness could be anywhere in the range of 5 HRCs
Better than nothing I suppose
31st Dec 2021, 07:10 PM #5Senior Member
- Jul 2007
- 332
I have a set of the original files and they are better than nothing and a step up from a file only guess, but can be fiddly to use. If you have not seen before, the Stefan G video https://www.youtube.com/watch?v=U6SmsX44noo at around the 47 minute mark he compares them with a proper machine. Alan.
Lathe Bed Hardness
By YBAF in forum ANTIQUE AND VINTAGE MACHINERYReplies: 3Last Post: 5th Nov 2020, 08:35 PM -
4140 HARDNESS
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 6th Mar 2015, 08:01 PM -
Mig wire, hardness and annealing ?
By auscab in forum WELDINGReplies: 10Last Post: 11th Mar 2014, 09:33 PM -
Fun with a hardness tester
By .RC. in forum METALWORK GENERALReplies: 5Last Post: 19th Aug 2012, 07:52 PM -
sheraton bed hardness
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 14th Nov 2011, 08:04 PM
