Results 1 to 15 of 24
26th Dec 2021, 02:16 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
4 x 6 Bandsaw Hydraulic Downfeed Cylinder
The Cylinder arrived Xmas eve.
It is bigger than I expected...lol ( Don't know why I thought that....)
Need to think about how/where to mount it to get maximum travel and best adjustment.
Think I prefer the right side, if possible , so I can see the progress easier. I think its designed for left side as the spring mount is on that side.
Will see.
26th Dec 2021, 05:02 PM #2Most Valued Member
Hi Steve,
Thanks for the Piccy, where did you get that from, as I wouldn't mind one myself???
26th Dec 2021, 07:35 PM #3Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
27th Dec 2021, 03:52 PM #4Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Screenshot of order:
27th Dec 2021, 04:43 PM #5Diamond Member
- Aug 2006
- 1,106
That's a good price, I've never used Alibaba before only eBay. Is it straight forward, last time I checked they don't use paypal.
27th Dec 2021, 06:32 PM #6Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
7th Jan 2022, 06:46 PM #7Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Have been looking at this, to try and work out how I'm going to fit this to my Bandsaw. Nothing is jumping out at me....lol
I think BobL and Baronj both had problems with their fittment and removed it in th eend. I'm concerned I will end up at the same place.
I have been thinking about how to get the most useable travel out of the cylinder. The bandsaw arm has to be able to travel 90°( so vertical cutting can be done ) , but it does not need to interact with the cyclinder until the lower 50% of its travel. It seems to me, the cylinder needs be mounted horizontally to allow easy manipulation of the controls.
I've worked out how to do it in theory. Need to make a model to test it.
This should mean that , for the last 50% of down feed, I will be able to use the full travel of the cylinder to control it, and hence, have better control over it.....I hope.
Is this something, if it works, that you guys would think improve its usfullness, or are there other reasons it didn't work for you guys?
I can try do a quick drawing in CAD, to clarify, what my plan is?
7th Jan 2022, 07:38 PM #8Member: Blue and white apron brigade
No, I still use mine for most cuts.
Mine is not fixed at the base end so can be flipped up out of the way if I need - it also means I can lift the arm up right out of the way.
7th Jan 2022, 08:59 PM #9
Hi Steve, Guys,
I found that it was much more effective to use the spring and adjust the motor weight as a counter balance !
When I made the new motor mounting plate the motor ended up about an inch further back. Bear in mind that the original motor had been replaced by a 1Hp Brooks cap start and run one, no centrifugal switch, so quite a heavy motor.Best Regards:
9th Jan 2022, 05:29 PM #10Member
- Brisbane
- 74
- 51
I bought a saw that came with a downfeed cylinder fitted (by maker). It won't lift to vertical with the cylinder in place but the top attachment is a simple bolt that I leave only finger tight and can detach in seconds. That done, it raises to vertical just like a standard saw.
10th Jan 2022, 06:34 PM #11Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
10th Jan 2022, 06:41 PM #12Member
- Brisbane
- 74
- 51
10th Jan 2022, 07:22 PM #13Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
The Nebadawn kit fits where the spring was and allows it to go vertical
SawCyl Band Saw Hydaulic Down Feed Kit
10th Jan 2022, 07:43 PM #14Member: Blue and white apron brigade
I looked at those but the US$200 plus US shipping was going to be more than twice what my BS cost
I ended up with one of these dampers for ~$50 including shipping
https://www.ebay.com.au/itm/27504660...wAAOSwq4VbSUwy
10th Jan 2022, 08:29 PM #15Most Valued Member
- Mar 2011
- 1,555
I only linked it as an example of using the original spring pickup
Repair of hydraulic piston/cylinder
By BobL in forum AUTO RESTORATIONReplies: 25Last Post: 9th Jul 2021, 11:21 AM -
SA 20T Hydraulic Cylinder and Gauge (New)
By racingtadpole in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 14th Aug 2020, 12:01 AM -
Hydraulic Cylinder/Pump Calculations
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 21st Nov 2019, 12:47 AM -
Hydraulic Cylinder Fix
By RustyArc in forum METALWORK GENERALReplies: 11Last Post: 2nd Dec 2018, 09:22 AM -
Hydraulic cylinder for sale
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 22nd Apr 2017, 08:50 AM
