Results 1 to 5 of 5
Thread: Graciano Sag 180 Lathe
25th Dec 2021, 08:49 AM #1New Member
- Jul 2009
- Pascoe Vale South
- 1
Hello All,
I recently acquired a Graciano Sag 180 Lathe, however the manual has been lost. The quick change gear box does not list a 13 TPI thread. I am sure I will eventually need to cut a 1/2" UNC 13 TPI thread (or perhaps a 26 TPI Brass Thread). As this lathe was sold to the US there must be a way to cut a 13 TPI thread by using some of the change gears. The assistance I require; has anybody the Graciano document which advises the change gears on the required on the compound gear train when cutting pitches outside the range of the quick change gearbox.
Txs & Regards F T
25th Dec 2021, 09:55 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Some free Graziano manuals here:
https://archive.org/download/lathe-manuals
25th Dec 2021, 11:54 AM #3
Hi Frank
Welcome to the MetalWork Forums,
You have landed among a great group of metalwork enthusiasts .
There are very experienced and knowledgeable people who are willing to help each other .
You are likely to find help for your lathe here. There are Sheraton and Hercus forums but the rest of us post lathe stuff in the Metalwork General Forum.
We encourage you to have a look through the entirety of the forums.
You can do this by going to:
FORUM ( Box ) at the top LH corner of the page and click
Which brings up the pull down list and select Forum Home a page to scroll down with clickable headers.
There is about 30 odd pages to select from and at the verytop being the terms of Use -Our Rules - please read them.
The rest are topic forums or assistance pages to the members.
There are stickies and guides attached to most pages which we as people to read and understand before making posts in them. In the scroll down page there is a
Welcome wagon forum -
New members can post there and tell us about them selves thier metal work intersts and the tool and equipment they have.
Merry Xmas and welcome to the forums.
Just wondering . How come you waited since 2009 to post in our forum?
Welcome Frank
26th Dec 2021, 10:45 AM #4I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
I take it you have the early version of the SAG 180, same as mine, which only has 3 'letter' positions (A, B, C) and 6 'number' positions, as the later versions with 4 'letters' and 10 'numbers' had both 13 and 26 tpi listed on the chart. I have never come across a manual for this earlier variant, if you do find one I'd love to see it.
The good news is that I have previously looked at how to cut 13tpi, knowing like you eventually I'd need it, and it's as simple as swapping the gear on the gearbox shaft to 52T (instead of 80T), and selecting Whitworth/B/2.
26TPI is more of a stuff around, as B is the 'finest' thread position of the letters, but can be done no worries.
If you have a windows PC, private message me your email, and I'll send you a copy of the 'Lathegears' program written some years back by a member here, along with the setup file for the SAG 180 that I wrote after counting all the gears in the box to double check I had them right, and including all the change gears I have (think that's the full set). Then you can just type in whatever pitch you desire, and it will output a whole list of options and their accuracy - like so, for 13 TPI (Mine is currently set up with a 44T idler, hence the highlighted bar, although I haven't physically tried it, so it may require a different idler as well in order to actually fit).
If you haven't already dragged them off the web can also send you the later SAG 180 manual, and the SAG 14 manual (the same machine with mostly minor updates), which can be helpful if you're digging into it, although there are some small differences to the earlier models.
You also might find this thread useful, depending on what you're doing: https://metalworkforums.com/f303/t20...iano-sag-180-a
Note there is some inaccurate information here and there - for example, I'd use one size longer belts if I were doing it again. If you have any questions about something, feel free to ask in there, and I'll answer if I can.
26th Dec 2021, 03:40 PM #5Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum Frank.
Ross
Any Atlas Lathe and Drummond Lathe Owners out there?
By j.ashburn in forum METALWORK GENERALReplies: 3Last Post: 8th Apr 2013, 06:22 PM -
By Auskart in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 29th Jun 2010, 07:02 PM -
