Results 1 to 12 of 12
Thread: Kondia owners PLEASE help......
18th Dec 2021, 02:49 PM #1
Hi all,
I have a FV-1 Kondia step belt pully J head.
My problem is the timing belt has broken and I need to find a replacement.
I can't find anything online at all.....
I took the belt to my local bearing supplier who stocks and or can source timing belts etc.
I need a 42 tooth belt and there is no such animal.
Online searches for milling mmachine timing belts brings us many different sizes and tooth counts, but absolutley nothing for a Kondia.. I find it hard to believe there is no such thing.... If this is the case every Kondia out there will
end up at the scrap yard.
Please please help.
Thanks in advance
MattWarning Disclaimer
18th Dec 2021, 03:08 PM #2Most Valued Member
- Healesville
- 2,129
Matt if you are after the belt for the variable speed it won't matter about the tooth count, i think you might find that it is a cogged belt and the cogs are there for cooling. So you just need the correct length and width......
18th Dec 2021, 03:39 PM #3
18th Dec 2021, 04:05 PM #4Most Valued Member
- Healesville
- 2,129
That is stooopid place to put a belt. this drawing shows the belt here https://www.lwta.net/photos/KONDIA-FV1-CNC-REBUILD.pdf
A post on PM https://www.practicalmachinist.com/v...isting-324375/ quoted the part No as Timing Belt (used for low gear) HTD560-8M-30 x 1
A search on googs brought this up https://www.ianboettcherraceparts.co...560-8M-30.html That was the only one i looked at and it does not say how many teeth it has so maybe shoot them an email.
18th Dec 2021, 05:10 PM #5Most Valued Member
- 2,651
Shed, the HTD belts are in mm pitch, so an 8M is 8mm pitch.
560 belt would be 70 tooth - so doesn't tie up with the OP's 42 tooth.
If it IS a HTD8M that would tie up with the local belt place saying that there isn't a 42 tooth, as it looks like they jump from 40T to 44T:
https://www.naismith.com.au/upload_p...52dfbe0ff5.pdf
Matt - is there any form of tensioner on the belt, and how did you work out that it needed to be 42T?
18th Dec 2021, 05:17 PM #6Golden Member
- Apr 2009
- Kingswood
- 930
Matthew,
My FV-1 has the stepped pulleys for speed adjustment, not the matched cones for speed adjustment.
But, it has a 42 toothed belt for the backgear.
Uniroyal PowerGrip 30293 x 1 1/4 B9N1
It was purchased locally in Sydney, I think from a belt distributor, not a retail outlet.
Keep well,
John.
18th Dec 2021, 06:10 PM #7Member
- Mar 2012
- adelaide
- 91
My Kondia has the Variable speed , the belt i removed when i replaced it ,the bottom belt was a Gates Power Grip 40173 X 1 1/4 , i wrote on it H section 1/2 inch pitch 42 Tooth , i struggled to get a replacement from the usual sources and i think i ended up getting one on EBay ,
18th Dec 2021, 07:03 PM #8Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
When you do find a source, it might pay to buy 2 or 3 so you have a couple of spares.
18th Dec 2021, 07:31 PM #9Most Valued Member
- 70
- 1,511
19th Dec 2021, 01:29 AM #10Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
I think you'll find Kondia are made by Lagun and branded with a few different names. Mine is a Pacific but parts come from Lagun in Spain.
20th Dec 2021, 06:41 AM #11Most Valued Member
20th Dec 2021, 06:47 AM #12Most Valued Member
Last time I sourced a belt for my Pacific mill, I found these guys sell the belt I needed.
H & W machine repair. They are in the US and I have found them very helpful in the past.
Sent from a galaxy far far awayGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
Kondia serial number
By Reidy41 in forum METALWORK GENERALReplies: 1Last Post: 23rd Aug 2021, 04:24 PM -
Kondia Powermill FV-1
By Lloyd W in forum CNC ForumReplies: 6Last Post: 2nd Feb 2020, 01:40 PM -
Kondia mill
By Davo81 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 3rd Jun 2019, 04:07 PM -
Kondia Clock Spring
By sossity in forum METALWORK GENERALReplies: 4Last Post: 11th Jan 2017, 07:23 AM -
Aussie AL-960 owners or previous owners input please?
By befuddled in forum METALWORK GENERALReplies: 4Last Post: 6th Jun 2015, 10:14 PM
