Results 1 to 15 of 41
Thread: 4 x 6 Bandsaw Coolant Mod
16th Dec 2021, 06:17 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Have moved on to the coolant pump mod now.
Got the return line secured so I can remove the basket for cleaning and have the outlet mounted above the blade.
Re: coolant.
I've had a bottle of HOCUT 797BU I got from H&F ages ago. I looked to see if it can/should be diluted with water but cannot find any mention.
Anybody know if it should be and what ratio it needs to be?
16th Dec 2021, 06:33 PM #2Member: Blue and white apron brigade
From this https://www.toolprocure.com.au/asset...stralia_v2.pdf
HOW TO USE RECOMMENDED USE CONCENTRATION
Machining 1:10 to 1:20
Grinding 1:20 to 1:30
16th Dec 2021, 07:01 PM #3
I use a speaker magnet around the drain hole, and the in the funnel which is where your basket is to catch metal shavings before they go into the tank.
I also use a round piece of flyscreen wire in my funnel to catch aluminium,brass, plastic etc, it's easy to take out and rinse off.
I have never had anything in the tank in 15 or more years.
Sent from my 5007U using TapatalkUsing Tapatalk
16th Dec 2021, 07:44 PM #4
16th Dec 2021, 09:20 PM #5Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,553
The way you’re cracking on with that you’ll have plenty of time to build that electric punkawallah
Coming along nicely, I’ve already sold the coolant tank out from the stand though..
16th Dec 2021, 11:01 PM #6Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
17th Dec 2021, 11:22 AM #7Most Valued Member
- 4,258
17th Dec 2021, 01:47 PM #8Member: Blue and white apron brigade
A more accurate method is to use a refractometer to measure the refractive index of the mixture and then multiply that by a fudge factor OR calibrate the refractometer to known concentrations.
Then add water or more concentrated lube as required.
If the dilution goes below a certain level it can easily rust machinery.
The presence of other oils (way oil etc) can screw with the refractometer readings so the whole lot may need to be replaced every so often.
22nd Dec 2021, 06:19 PM #9Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I finished the new on/off switch today. The stand provided a nice location to fit another bracket. I even had an off-cut cut to the correct angle.
Was thinking about IF I would not need to run the Coolant Pump for any reason, whilst using the bandsaw....Not sure I would, so I will hard wire the pump to the motor terminals to KISS it.
Later, down the track , if that is a incorrect assumtion, I will either add a plug and socket to the pump cable( So I can easily remove the pump and tank for cleaning ) or fit an inline switch.
Been looking at brushes to clean swarf off the blade.....Not sure I have room on this little saw.....Will see
22nd Dec 2021, 06:40 PM #10Most Valued Member
22nd Dec 2021, 06:52 PM #11Member: Blue and white apron brigade
Mine has an in line switch so if I leave that switch on the pump goes on and off when the main motor does. However, it does take about 3-4 seconds for the lube on my setup to find its way from the tank up to the blade so to prevent the blade running dry at the start of the cut I start the motor with the blade is a mm above the workpiece so by the time it touches the work piece the lube is coming through. Sometimes I just hold the blade rm above the work and once the lube comes through I let it go
22nd Dec 2021, 06:56 PM #12
Hi Sterob
Luv the mods. They came out well.
As for the swarf brushes. I used a 25 mm rotary brush mounted on a 6mm shank. It was fitted into a bearing block and mounted on the bottom-if the blade was standing vertical . If yours is the BS4 size Bandsaw it will fit
They wear out but work OK. Its taken off at the moment as I needed to buy a fresh one .If I get a around tooit , I shall dig it out and mount it and take a pic for you.
22nd Dec 2021, 07:41 PM #13
Mine just has a simple toggle switch from factory, I'd be worried yours will fill with coolant.
I know it may have a clear plastic cover, but it will break down eventually.
22nd Dec 2021, 07:47 PM #14
This is my simple coolant switch on the motor terminal box.
It's wired straight from the motor like yours, so when the saw is switched on I have the choice to have the coolant on or off.
I use the vertical often so needed a way to turn the coolant off.
22nd Dec 2021, 07:57 PM #15
I've never used wire wheels but looked into it years ago, I find the coolant flushes it off the blade even with the gummy welding grade aluminium.
Just looking at your welds and to give a tip, crank up the amps.
It's come up great, and here I am 10 years on after saying to myself I'll make a new stand and have the materials and haven't done it.
Me being me I want to make mine onto a full swivel both ways like the bigger $4000 saws with sliding vice etc. I always have to over complicate things for some reason, lol
Bandsaw questions- and identify my old bandsaw?
By Pete O in forum METALWORK GENERALReplies: 4Last Post: 23rd Apr 2020, 12:14 AM -
Bandsaw coolant system
By th62 in forum METALWORK GENERALReplies: 7Last Post: 24th Jul 2014, 05:32 AM -
Bandsaw Coolant
By Dave J in forum METALWORK GENERALReplies: 19Last Post: 6th Feb 2012, 08:01 PM -
which coolant ?
By Dusty Wheels in forum METALWORK GENERALReplies: 16Last Post: 1st Oct 2009, 08:06 AM
