Results 1 to 15 of 15
14th Dec 2021, 01:17 PM #1
Can I pick the collective brains about circlip pliers ?
Hi folks
I would like to trawl the collective knowledge about circlip pliers sets.
I have just finished a little job which required the use of external circlip pliers.Naturally I did not have the correct type and found the task harder than it should been .I want to buy some , a set of them.
Hence, I would like advice on paperclip pliers suitable up to 50mm (2'') diameter.
Of course I don't want to go too cheap and conversely not too expensive.The uses are probably only for occasional use, but! when you need them ,you need them.
Ladies and Gentlemen what have been your experiences and opinions with circlip pliers?. What are those to avoid and the ones worth chasing up?
The suitable to my needs circlip pliers. Who sells them? I had a quick look at the usual suspects -Total tools and Sydney tool but nothing stood out.
Thank you in advance.
14th Dec 2021, 01:47 PM #2Senior Member
- Oct 2015
- melbourne
- 473
I bought a set from super cheap.(their housebrand, tti maybe?
Seem as good as any at launching circlips across the room.🤣
Haven't used them a lot but so far ok.
Russ
14th Dec 2021, 02:41 PM #3
I have quite a few brands in my arsonel that I have collected over the years, But like Russ I bought a set of the Super Cheap ones and have used them quite alot over the last year or so. I am no expert, but they seem as good as any. I have had no drama with them and would expect them to perform perfectly for home hobby use and price is very reasonable.
The usual applies.
I'm not affiliated etc etc.
MattWarning Disclaimer
14th Dec 2021, 03:37 PM #4
I swear by Knipex pliers, they've never let me down at the race track, unlike some el-cheapo brands I've used, they grip the circlip securely so you don't need to play hunt-the-escapee... You pay a bit more but I reckon they are well worth it.
14th Dec 2021, 04:05 PM #5Most Valued Member
- Jul 2016
- 35
- 1,522
Yeah I use knipex, I flog them pretty hard and I've never had a tip snap, whereas every non knipex pair I've ever owned has died.
I do have some internal external ones made by Wright tool in the USA with interchangeable tips, but I use these for little ones. They are good though.
14th Dec 2021, 04:26 PM #6Diamond Member
- Aug 2006
- 1,105
I have a set of 4 from Repco, internal and external, bent and straight. I have had them for nearly 15 years now without any issues, they don't see a lot of use but handy to have around.
Any of the cheap brands such as what is sold at supercheap should be sufficient I would think, quality of chinese tools has come a long way.
14th Dec 2021, 05:29 PM #7Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
I have a reversing set that also has interchangeable tips made by Snap On and a couple of pairs of Knipex.
Search snap ring pliers, unfortunately Australia is becoming an annexe of the US and a lot of tool suppliers are using US terminology.
14th Dec 2021, 07:57 PM #8I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
My tip is not to bother with the style where you swap the tips around... Never laid my hands on a pair of those that were any good, way too much wobble between the body and the tips, and usually weak steel as well. You probably can get decent ones if you spend enough money, but I don't need to look.
I use Snap-On ones that swap between internal and external by unscrewing the pivot screw, rotating one handle so the tip is on the other side of the other tip, and screwing it back together.
I've a couple of them, but my go-to 95% of the time is this one: https://shop.snapon.com/product/Snap...Red)/SRPCR7090
I also have a 45 degree pair with smaller tips, and a straight pair with the same size tips, as well as a duplicate pair of the above.
I don't think the price is unreasonable, given that I was working as a mechanic at the time I bought them, and one of those 90 degree pairs has seen service in that role for over 10 years, before entering 'semi retirement'. It's released circlips that have had bearings jammed hard up against them, and had a ridiculous amount of force applied to it that would have destroyed a lesser pair - trust me, I binned more than a few of those before I got the Snap-On. The reason I have a duplicate pair is I threw the remains of a cheapo interchangeable tip set over the back fence in absolute rage one day when working on something at home, and went straight on the rape truck the next week and bought the duplicate pair for home use.
The advantages of those Snap-On style are that you only need one pair for both internal and external, and because the pivot bolt is just a thumbscrew, you can always take out any flex between the two handles, which is usually the other killer on cheap ones. Spreading the circlip is only half the battle, any decent circlip often then needs to be twisted out of place as well. The Snap-On ones are so rigid that most times you can just lift the circlip out with the pliers, whereas a cheaper set of pliers requires you to get a pick or small screwdriver in there as well, because putting any side load on them makes them slip out.
Probably sound like a rabid fanboy about now, but I can assure you that contrary to how it may sound, there is only a smattering of Snap-On gear in my big rollcab, carefully selected and mixed in with plenty of other brands. A lot of the Snap-On stuff is absolutely ridiculously overpriced and not worth it. Some of it is only worth the price if you're in a trade and using it every day, or have specific jobs you need them for - stuff like my long ring-ring spanners with a 15 degree offset, and a couple of other selected sizes of combination spanners, and the 1/2 and 3/8 drive flex head ratchets with really long handles. Not worth the cash to someone who doesn't spend all day dealing with inaccessible or gorilla torqued bolts. And some things they make are absolute gold for the price even for the average punter in their shed - those circlip pliers for my vote are one of the best examples of the latter.
14th Dec 2021, 08:14 PM #9Most Valued Member
- 70
- 1,511
I have the Knipex straight and bent in external and internal. They are excellent. If not in a hurry, wait for a special from one of the tool retailers. There is also a place for the cheap interchangeable tip type, for small awkward places. They have saved me a few times. I also have a cheap set of miniature ones for small circlips with very small pin holes.
Nev.
14th Dec 2021, 08:31 PM #10Philomath in training
- 6,541
I have Knipex internal and external sets, as well as a Kincrome with the changeable jaws as Jekyll and Hyde mentions. The biggest problem I have with that is the spring wants to play hide and seek all the time. Other than that, no problems with them. (mine are so old they have red handles)
Total tools have them as a special order for $35, but others would stock similar.
14th Dec 2021, 08:40 PM #11Most Valued Member
- 70
- 1,511
14th Dec 2021, 08:46 PM #12Most Valued Member
- Mar 2011
- 1,536
To hijack the thread for a moment..
You espouse the virtues of their circlip pliers, I will never buy another ratchet that is not a Snap On 80 tooth
After trying a Snap On 80 tooth ratchet after they first appeared about 10 years or so ago I promptly ordered a set of three and sold every other ratchet I owned at the time.
14th Dec 2021, 09:55 PM #13Diamond Member
- Jun 2010
- Canberra
- 1,322
I have a set of those wobbly multi-head pliers that others have mentioned, and are handy to have for the oddball scenarios, but 90% of the time I use a pair of straight Knipex.
17th Dec 2021, 09:47 AM #14Most Valued Member
- 2,651
Used the SnapOn ones many years ago, but I didn't own them - they were provided by work. Awesome!
Knipex ones are mostly what I use now, but do have an interchangeable tip style for small/infrequent stuff.
Regarding dealing with the ping "ah-crap!" style of circlips, the best tip I've ever been given is to put the part in a clear plastic bag, or at least cover it with one.
Better than using a rag for containment as you can still see what you are doing. Plastic bags are also great to use for any part that has small bits like ball bearings or springs that tend to escape.
20th Dec 2021, 04:59 PM #15
Thanks everybody,
I went for the KingChrome ones like MichealGs .
None in Mackay ( naturally) so it will be an after xmas present.
Thanks for the feedback.
Strange Pliers
By jack620 in forum METALWORK GENERALReplies: 7Last Post: 28th Nov 2021, 04:18 PM -
Knipex Circlip Plier Set
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 8Last Post: 30th Sep 2021, 09:19 PM -
MIG Pliers
By Sterob in forum WELDINGReplies: 6Last Post: 5th Feb 2021, 08:41 PM -
Removing a Broke Circlip /C-clip From Spindle
By thumbsucker in forum METALWORK GENERALReplies: 5Last Post: 4th Jun 2015, 07:49 PM -
Shaft diameter for circlip
By variant22 in forum METALWORK GENERALReplies: 4Last Post: 6th Jul 2013, 02:52 PM
