Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Nov 2021
    Australia
    194
    Well, I've made a little more progress with my attempt to modernise my bandsaw guides.
    I have now mdae and figured out an attachment method that looks to be workable.
    I still need to paint it, but here is a couple of pic's of what I have.
    Next step is to figure out to achieve something similar for the under table guide.
    It wont be an exact copy of the top setup as space is limited.
  2. #32
    6,480
    Hi Oddbod,
    Looking at your pictures, it seems that you only need a couple of bearings to replace those brass guides ! Though I must admit that they seem fine enough for the job.
  3. #33
    Jan 2004
    Mackay North Qld
    6,446
    The proposed bottom bearings and the supporting assembly could be reduced in sizing.
    What needs to be considered is the table on its maximum swings .
    I had a similar woodwork bandsaw that I was going to do wonders on a big stick with it.
    Unfortunately in 2008 a big flood got in way. Its on my gunnadoo list still.
    I think the saving grace is that the saw band stays in the same plane where it is quite different of the 6x4 type of saws as the
    band comes off the drive wheel and is twisted to align into the cut plane at one bearing and then goes back to normal,after it passes the opposite bearing.
    I have seen more than one 6 x 4 type band blade rolled out of flat with a hump in it, in my opinion, was due to over adjusted bearings and poor tension. No such problems with the vertical bandsaw, I reckon.
    It shall be interesting to follow the progress.
  4. #34
    Nov 2021
    Australia
    194
    Thanks, for your constructive comments gents.
    Sorry about the double post previously, I have no idea why or how that happened.
    As usual, I am waiting for paint to dry and contemplating my next move.
    I am warming to the idea of maintaining the rear bearing as it is and just add a pair of side roller bearings and see how it goes from their.
    That way it should save my a lot of time.
    More soon.
  5. #35
    Dec 2005
    South Australia
    1,658
    Leave the bottom guides as they or maybe replace the brass faces with tungsten it is a far superior system.
  6. #36
    Nov 2021
    Australia
    194
    Quote Originally Posted by Oddbod1 View Post
    Sorry, I've been off the radar for sometime as I hurt my shoulder which has limited my progress.
    Anyway, I have managed to make a under table roller bearing guide.
    My version really only adds the side bearings and I have stuck with the original configuration of the back of blade bearing at 90 degrees to the blade.
    Lack of space was the problem for the back bearing modification.
    However if somebody set their mind to it, I am sure it would be possible, just a lot more work involved...
    All appears to be ready to go, but as yet I have not been able to give it a run.
    I hope to do that soon and report back with any feedback that maybe of help to future modifiers.
  7. #37
    7,189
    Good work.
    Suggest replacing the slotted head screws with socked heads as these can be tightened firmer and easier.
  8. #38
    Nov 2021
    Australia
    194
    Good work.
    Thanks Bob and yes a good idea for the bolts/screws.
    Just looking around my stash to see if I have any socket heads with matching threads.
    I go to buy stuff and later on I discover, I already had the same stuff hidden away for a rainy day.
    Hahaha.
    Old age, its a challenege at times...
  9. #39
    7,189
    If they are imperial threads them expect to pay a more.
    Well at least last when I needed 16, 1/4" BSWs I had to settle for NCs and they cost a lot more than metric equivalents.
  10. #40
    Nov 2021
    Australia
    194
    I think I paid $38 for a 1.6m 14TPI bimetal blade but that was some time ago
    You could try Hughans
    We buy our Timber Mill Band saw blades from them.
    Address: 14 Hector Street, Osborne Park WA 6017, Australia
    Phone: +61 8 9244 1977
    I've also bought blades from Carbide Tools In Wangara. https://www.carbidetool.com.au/products/
    Ask them all for a quote.
    Thanks Bob, yes that is where I recently purchased my two blades, they run at about $58 each these days.
    I guess length and size also influences the cost, I am lead to believe the blade material is from the USA, which is comforting also...
  11. #41
    Nov 2021
    Australia
    194
    Yes Bob and some of the nut and bolt places have a minimum charge which kinder irks me...
    I'm sure I have some, just need to dig them out.
    Probably have surplus from previous minimum charge buys where I end up with a much larger quantity of fasteners to cover what they want as a minimum charge which has varied from betweem $10 and $20 at times.
  12. #42
    Nov 2021
    Australia
    194
    Still have not had a chance to give my blade mods a trial run as yet, however I found an old bench saw aluminum guide in a scrap bin and decided it maybe useful to one day.
    Well, I got to thinking it may well a suitable guide on my bandsaw table.
    I made the orange coloured components trimmed the end off as it was a little too long and reduced the sides near to the locking screws for finger clearance and now I have a functional table guide which has got to be better than no guide...
    I have also added an extra long chord ro my bandsaw to reach my 3 phase power outlet.
    The chord was too loong to store easily when not in use so I made a hook out of some stainless steel flatbar and attached to the saw frame.
    I guess it looks OK and is functional.
  13. #43
    Nov 2021
    Australia
    194
    Well, I guess I'm done with this bandsaw thread for now.
    I will post a performance reply when I actually get around to using it.
    Right now, I've been distracted putting wheels on a treadle guillotine I acquired recently.
    It is something like my bandsaw, that I dont expect to use daily, so it is mice to have it mobile to move out of the way and store.
    I put wheels on my bandsaw as well which turned out to be really helpful.
    Both the bandsaw and guillotine are qyuite heavy and would be difficult to move around easily or safely
    The bandsaw was easy and I just got a ste of locking castor wheels from the local hardware for $35.
    However the guillotine seemed much heavier in my book, but I did score a pair of trolly castor wheels used by a school teacher to move something around the school.
    They had good double wheels but no locks, and seemed to be capable of carrying decent weight.
    So for $20 I bought the two trolleys and cut them up and recycled them into a configuration that would work with my guillotine.
    It worked a treat, but I wanted to have a method of locking the unit in place but also take the load off the wheels, especially when using the treadle and an extra 100kg of body weight using the treadle was probably not an idea that would see any longevity of wheel life.
    I acquired 2 x 2nd hand trailer jockey wheels for $10 each, chopped off the wheel yoke section and made a floppy foot that could be wound down.
    Attached are pic's of my madness...
  14. #44
    May 2019
    Picnic Point, Sydney
    77
    314
    Quote Originally Posted by China View Post
    China is spot on there. With rollers/bearings every bit of swarf is being crushed between the rollers and blade. Different thickness hardened guides scrape the swarf away from the blade.
  15. #45
    May 2019
    77
    314
    I'll be interested to see your feedback. What you've created there is a hopper situation and if the bearings are properly adjusted to the blade then you have huge problems.
  1. Steelfast bandsaw lubrication
    By L8N in forum METALWORK GENERAL
    Last Post: 15th Jul 2021, 12:05 AM
  2. Steelfast Bandsaw original electric motor size
    By paul33 in forum ELECTRICALS
    Last Post: 14th May 2019, 12:29 PM
  3. woodfast / steelfast vertical bandsaw
    By monchochos in forum METALWORK GENERAL
    Last Post: 20th Mar 2019, 07:43 PM
  4. 14" Steelfast/Woodfast Bandsaw
    By lamestllama in forum METALWORK GENERAL
    Last Post: 27th Dec 2018, 07:59 PM
  5. SteelFast Bandsaw
    By Petip in forum METALWORK GENERAL
    Last Post: 18th Jun 2014, 01:43 PM
