Results 1 to 6 of 6
27th Nov 2021, 07:55 PM #1Diamond Member
- Aug 2006
- 1,106
Vice restoration, how to sort out little nick's and imperfections in castings.
Hi all,
I have an old Dawn 4sp vice here that I would like to do a restoration on, there are a few nicks in the casting where it looks like it has been hit with an angle grinder, but they look very minor to me compared to what I see on the vices at my workplace.
Anyway would be be the best way fix these. I have access to Mig, tig, arc and oxy or would something like an epoxy such as jb weld be a better choice?
I still need to strip the paint down to the bare casting.
Any suggestions would be great.
27th Nov 2021, 08:40 PM #2
I did a resto on a Record #3.
For no reason other than the fact that I had them at hand, I melted some Nickel 99 stick rods into the gouged and dings, and then ground / polished them flat. Adds a nice effect of silver patches where a paint finish will not be used.
I'd be equally happy with a hard epoxy filler if there will be paint and filler used in the final coating system.
27th Nov 2021, 09:01 PM #3Philomath in training
- 6,563
Because it is cast (and I think the SP means spheroidal graphite too), welding is probably not going to be good for it. A wipe of epoxy filler is probably quickest and easiest.
27th Nov 2021, 11:02 PM #4China
- Dec 2005
- South Australia
- 1,658
Mostly people just use body filler, personally I would just leave it.
28th Nov 2021, 03:08 PM #5Gear expert in training
- 34
- 1,080
+1 for epoxy or body filler if you want to make it pretty, or just an extra thick coat of paint if you're just going for function
29th Nov 2021, 08:56 AM #6Diamond Member
- Aug 2006
- 1,106
The epoxy seems like a no brainer.
Thanks for all the suggestions.
What sort of vice is this?
By MarionN in forum METALWORK GENERALReplies: 6Last Post: 28th May 2020, 08:16 PM -
Record No21 Quick Release Engineers vice restoration
By warrick in forum METALWORK PROJECTSReplies: 0Last Post: 23rd Mar 2020, 04:54 PM -
Vice restoration
By kenny_10 in forum METALWORK GENERALReplies: 12Last Post: 21st May 2019, 07:43 PM -
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
Pinging Nick Mueller
By Machtool in forum METALWORK GENERALReplies: 17Last Post: 6th Jun 2012, 11:03 PM
