Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Jul 2007
    sandstone point queensland
    69
    182
    Default foolproff threading
    made this tool up for thread cutting,works a treat ,cuts the thread ,reverse lathe move cutter in then cut again etc etc
    34
    1,075
    It just looks like a standard insert threading tool...what am I missing?
    Jun 2007
    sydney ( st marys )
    64
    4,887
    I think this method relies on only retracting the tool by pulling on a lever, all other operations required for threading would then be followed.
    If it is as above and depth of cut is set by the plunge method, a suitable advance towards the chuck on the compound may be required depending on how coarse the thread is.
    34
    1,075
    Ohhh I see it now, the holder pivots on the bolt in the back.
    Aug 2006
    1,105
    You might not need to pull a lever at all, it might retract itself as it reverses.
    Jul 2007
    69
    182
    the tool cuts once the auto feed lever has been activated,when the thread has ended the direction is reversed,the insert bit lifts up and when it goes back to the start of thread wind in a little and go again,all the time the feed lever is down,no need to use the thread dial at all .......bob
    https://youtu.be/YZkRNdXFYB8?t=19 sort of like this one
    Aug 2006
    1,105
    Do you have plans for it, wouldn't mind making one
    6,436
    It reminds me of Professor Chadwick’s flip up tool holder !
    Its been published in several books and magazines several times. If I can lay my hands on the pdf of the article, and assuming its not copyrighted I can post it here !
    Dec 2013
    56
    1,416
    The pivot threading tool was a big hit around 10-15 years ago with many guys making them with many variations made to take out sideways slop.
    I was always going to build one but life and issues got in the way.
    Still threading today using the old school method, one day, lol
    Sent from my 5007U using Tapatalk
    Using Tapatalk
    6,436
    Aug 2019
    Revesby - Sydney Australia
    56
    1,183
    I always wondered about these flip up threading tool holders. Haven't made one yet.
    (no reverse on the Hercus, and no big "washing machine pulley"
    spindle handle, for manual cranking, like on Baron's?)
    • On a fine thread, would the bottom of the cutting tool drag all the way back?
    (i.e. slightly deburring the thread)
    • What happens when they start to stick/jam on a big threading job?
    (I guess it is just the end of the thread that would be slightly munged)
    At least Bob's one here seems to have a manual lever to reef the tool up with.
    • One of the designs I have seem was spring loaded.
    You hold it down to start the cut,
    the spring is held down by the cutting forces,
    and as soon as it gets to the relief groove near the chuck, it pops up!
    • Another design I saw was cam'd somehow.
    Down and up were the stable/resting positions.
    When you reversed, it pushed the tool up past the cam and well clear of the job.
    It could also be used with an end stop ramp or pin, for threading without a relief groove.
    • There might have been another one where the tool swung to the left and away.
    You needed to hold it right to start each threading pass.
    Just also had a thought: a large carbide insert holder, like an SER2020 or an SER2525,
    would save some machining time for the flip up bit. Just drill a hole in it for the pivot !
    Make sure it is a cheap one made from soft steel
    Anyway, might have to add this to the mental to do list.
    Sep 2006
    Australind , WA
    58
    1,277
    Still plenty of time Dave....
    Aug 2007
    Saskatoon, Saskatchewan, Canada
    292
    I'm not quite sure if my lathe can be flicked into reverse automatically but something to look into.
    I stumbled across a similar holder for inside threads than might be of interest. https://www.youtube.com/watch?v=_KGYAmaNfXY
    Pete
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Like Dave, something I've thought about off and on over the years; they also feature in model engineering magazines occasionally too.
    I'm a bit uneasy though with things like this to do common operations, as while you use one, you are not actually refining the skills necessary to produce decent threads on any suitable lathe. Similar issue with parting - while lathe condition is a factor with parting as well, trick holders and rear tool posts don't always do you a favour. It's practice as much as anything with a lot of these operations.
    Having said that, if it works for you, go for it.
  15. #15
    Nov 2007
    melbourne australia
    3,228
    I had to cut two 10x1.5mm male threads yesterday. I had my solid toolpost on the lathe and was too lazy to swap it for the compound. So I just used the crossfeed dial and added on 0.1mm with each cut. Used the half nuts and wound the carriage back to the start with the wheel (no reversing the lathe). First time I've cut a thread without using the 30 degree compound offset method. It worked a treat. I sometimes wonder if we overcomplicate things.
  1. Threading bit.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 20th Jul 2019, 09:30 PM
  2. Need some help threading
    By Ghrober in forum THE HERCUS AREA
    Last Post: 15th Oct 2016, 01:03 AM
  3. Replies: 5
    Last Post: 11th Sep 2015, 07:22 AM
  4. need help with threading
    By justron in forum METALWORK GENERAL
    Last Post: 2nd Sep 2014, 11:04 PM
  5. Threading again
    Last Post: 10th Dec 2011, 03:16 PM
