Results 1 to 7 of 7
21st Nov 2021, 12:00 PM #1Member: Blue and white apron brigade
Files - drag or lift when going backwards?
Here's a dude doing pretty neat and convincing testa on effectiveness or otherwise of dragging or lifting files when going backwards.
21st Nov 2021, 02:18 PM #2Senior Member
- Apr 2021
- 212
21st Nov 2021, 05:13 PM #3Most Valued Member
- 2,673
21st Nov 2021, 05:35 PM #4Member: Blue and white apron brigade
21st Nov 2021, 05:38 PM #5Senior Member
- Apr 2021
- 212
21st Nov 2021, 07:20 PM #6Most Valued Member
21st Nov 2021, 08:49 PM #7Member: Blue and white apron brigade
The steel used in chainsaw chains is relatively soft so they can be sharpened with a file.
On nost modern chains the cutter tops and sides are Cr plated and filing the steel underneath the Cr causes it to come off forming a hard edge..
Sometime the Cr plate comes off in bigger flakes than usual like this.
When a chain goes blunt that means the Cr edge has had gone and the edge rounds over like this.
SA Free cable drag chain
By racingtadpole in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 18th Apr 2021, 07:11 PM -
Trailer Lift
By Sterob in forum METALWORK GENERALReplies: 19Last Post: 20th Dec 2015, 11:43 PM -
Water lift
By rmm1 in forum METALWORK GENERALReplies: 26Last Post: 9th Aug 2011, 09:38 AM -
Hotstart vs lift arc vs..
By montiee in forum WELDINGReplies: 7Last Post: 14th Apr 2009, 03:07 PM -
GMF Motor runnig backwards
By bitza500 in forum METALWORK GENERALReplies: 7Last Post: 31st Jul 2008, 05:44 PM
