Results 1 to 4 of 4
Thread: Replacing Commpressor air line.
18th Nov 2021, 12:13 PM #1
The airline that goes from the tank to the tank to the pressure switch burst, its easy to disconnect the line from the tank but under the pressure switch there appears to be a shroud covering the other end, is there any way to undo it with out removing the pressure switch.
The Compressor is a SIP Eagle 2.5hp
18th Nov 2021, 12:29 PM #2Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
It looks like it might be a "Push In" fitting, you could try pushing up on the brass ring and at the same time pulling down on the tube to release it.
18th Nov 2021, 05:38 PM #3Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Just take the pressure Switch off . Its a lot easier.
Disconnect the wiring on the PS first. Take cover off and take some pics with your phone before you disconnect anything. It's probably only 2 or 3 wires.
Don't manhandle the Pressure switch to get it off. Use a spanner. The manifolds are usually made of cheese.
Oh, unplug the compressor and vent the tank before you loosen the switch....lol
17th May 2022, 06:33 PM #4
I patiently waited till I went down south, I asked Kryn where I could get some copper pipe, he said leave it with me, next time I saw him he had a length of plastic tubing, he said it was truck air brake pipe rated at 250 psi.
compressor back in action again.
Making An Upright Air Commpressor From An Old LPG Gas Bottle.
By wm460 in forum METALWORK GENERALReplies: 35Last Post: 26th Sep 2021, 07:05 PM -
Replacing the CVA compound
By caskwarrior in forum METALWORK PROJECTSReplies: 7Last Post: 18th Oct 2018, 08:47 PM -
Replacing a Switch.
By wm460 in forum METALWORK GENERALReplies: 9Last Post: 30th Apr 2017, 10:49 PM -
Replacing springs?
By Legion in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 14th Nov 2013, 08:09 AM -
Replacing Trailer Lights
By RustyArc in forum TRAILERS & OTHER FABRICATED STUFFReplies: 20Last Post: 24th Jul 2011, 06:10 PM
