Results 1 to 5 of 5
17th Nov 2021, 07:06 PM #1Most Valued Member
- 2,651
Don't give up on parting - I finally found a tool that works for me.
I'm know I'm not the only one who struggles with parting, or the only one that has a collection of destroyed parting tools/holders as evidence of that struggle and is familiar with the sharp "crack" sound a HSS blade makes when it shatters.
I've tried HSS blades in a couple of different styles and sizes, and also the MGEHR toolholders that take MGMN300 inserts.
Sometimes they work, sometimes I just can't get them to run without chatter or destroying themselves. Only thing that is consistent is I never know how it will go when I use them.
Here's part of the graveyard collection:
I'm convinced that with some parting tools the range of parameters they work well at is very narrow. Get into that range and they work really well, but just outside it they are horrible.
I've finally found a tool and insert that consistently works well for me. Its an old Sandvik holder and blade that I was given by a friend ages ago.
Takes Sandvik's 151.2 inserts which unfortunately aren't very common, or particularly cheap.
I'm sure there are similar styles that work just as well or even better with different lathes/operators but for me this is the best I've used so far.
After a few successful attempts, I decided I was confident enough to try parting with the power feed for the first time ever.
Worked well, and also meant I had enough free hands to take a quick video and brush on some oil at the same time:
https://youtu.be/0tM91kPYlo0
Its a great feeling when you can part with a bit of confidence - so if you're struggling, don't give up!!
17th Nov 2021, 07:36 PM #2I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
I had a Chinese knockoff of that tool for the AL335, think mine was the 26mm tall with the 3mm inserts (SPB26-3). Never had a problem with it, very rarely even changed an insert. Used a HSS blade for aluminium, the insert tool for everything else.
Got a similar SECO one with the Graziano, but where the old Chinese tool the insert was full width all the way to the back (ie. the slot for the insert is cut all the way through the 'blade', I think like your Sandvik?), this SECO takes an insert that becomes narrow behind the cutting edge, and is only half as wide as the 'blade'. Obviously the slot in the 'blade' is only half depth. Don't know whether the inserts I have for the SECO are really old school and fragile, the holder is flogged, my toolpost is rotating, or it's actually only intended for grooving, but I absolutely murder inserts in it - constantly losing corners, and sometimes breaking the insert in half.
Really do need to get myself another of the Chinese SPB26-3 tools to see if I can get back to annoyance free parting....
17th Nov 2021, 08:34 PM #3Gear expert in training
- 34
- 1,075
We use both TAG and DGN style parting tools/inserts from Iscar at work and they're amazing.
18th Nov 2021, 06:04 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
We just switched to the TAG style tool, everyone in the shop says they are the best parting tools they have ever used.
https://www.iscar.com/eCatalog/Famil...pp=51&GFSTYP=M
18th Nov 2021, 07:56 PM #5Gear expert in training
- 34
- 1,075
The J type inserts cut like butter on mild steel and other softish stuff, the C type is good for 4140 and hard stuff. There's also special ground tips for aluminium, brass and plastic but the J tips will do fine if you don't want to buy a pack of everything
Finally found a holy one
By eskimo in forum METALWORK PROJECTSReplies: 25Last Post: 7th Jan 2020, 08:37 AM -
Finally Found a Source of Alum for Broken Tap in Aluminium
By steamingbill in forum METALWORK GENERALReplies: 7Last Post: 29th Dec 2019, 11:59 AM -
parting off... or should I say ..how to break the parting off tool
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 19th Mar 2014, 02:29 PM -
Parting off tool ?
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 10th Oct 2013, 11:36 AM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM
