Results 1 to 15 of 15
Thread: Holding and indexing round stock
15th Nov 2021, 11:48 AM #1Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Hi everyone
I am looking for some advice on setup for a project I am working on at the moment please.
I have turned a tail stock tap and die holder on the lathe. The holder is approx 35mm in diameter and slides on a 19mm shaft. In examples of these types of holders most seem to knurl the outside to provide some grip. In my case I don’t have a knurling tool and thought I would flute it using a ball nose end mill. However holding is difficult and indexing even more so. I have come up with a vee-block in the vice as work holding but then if I make a groove as mocked up in the pic how will I ever go about indexing to the next flute? The size is too large for a collet block and even if I glued the holder onto a 19mm bar to use we collet block on the bar, I quickly run out of room on my mill.
Should I just go as I have mocked up and index using a protractor to eye ball it close enough? This is for hand holding grip and no accuracy really needed - although I’d like it to look “about right”. I thought this is a chance to try something I’ve not done before and if it goes pear shaped no harm really done.
Material is 316 stainless (what I had on hand) and other option for grip is to sand blast it but I thought fluting would be more fun. My mill is small (BCA jig borer) so light cuts slow and steady will be called for.
Ian
15th Nov 2021, 12:01 PM #2Most Valued Member
How many flutes do you want?
Do you have a set of lathe change gears?
Bolt one to the other end of your stock and index off that?
15th Nov 2021, 12:08 PM #3Most Valued Member
- Jul 2016
- 35
- 1,522
Hmm do you have a lathe? I would use the three jaws on a three jaw chuck (or four on the 4 jaw) with a block under the jaws to lay out scribed lines, then index the part by eye to reduce the number of indexing errors then use those scribed lines and a point to rotate it in the vice.
15th Nov 2021, 12:22 PM #4I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Make yourself a Rose Index.
https://www.youtube.com/watch?v=5ANx2AzPJzE
Been on my list to make one ever since I saw it.
15th Nov 2021, 12:35 PM #5Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Yes I have a lathe - that's what i used to make the part. I guess it sounds like marking out on the lathe then move to mill and eye balling will be best way.
I was thinking in the order of 8 flutes - every 45 degrees.
I do have some lathe gears and that is a nice thought to bolt one or something else to the end to index off!
Rose index - now that looks the ticket!
thanks for all of the thoughtful suggests so far guys!
15th Nov 2021, 03:47 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
Get a dress makers tape wind around your 4 jaw and mark the centre between the jaws.
Set a mag base or some other means of holding a pointer and aim it at the 4jaw.
Middle of one jaw, lock the chuck (I engage the back gear as well as the gear box, you’re not running the machine so it won’t hurt it) run the lathe tool in and use it as a scribe, release the chuck and rotate to the mark between the jaws, lock it and scribe. Move to the next jaw and continue until you have 8 scribed lines. If you want 6 do it with the 3 jaw.
Put it in your V block and centre the cutter on the scribed lines.
If you make the scribe lines deep enough the cutter can be used to index the part in the vice.
Could also count teeth on a gear to get your index marks.
15th Nov 2021, 04:05 PM #7Most Valued Member
- 2,673
On the lathe, make a small plug that will fit snugly in the end of the bit you want fluted, ideally with a step so it doesn't go all the way in.
Mark a horizontal line on it with your lathe tool while its still chucked by touching the end slightly with the tool and winding the cross slide.
Rotate spindle 90deg until the line is vertical (check with a square off the cross slide).
Mark another line with the lathe tool.
Find something that is 45deg (fold a piece of paper square then diagonally across the corners if you're really desperate) and rotate the spindle until one of the lines is at 45deg, mark, then repeat for the other 45deg.
Remove that bit from the lathe and poke it in the end of your workpiece. Put an alignment mark between the 2 parts so you can see if they move relative to each other.
From there, just line the first mark up vertically using a square, cut your flute - then rinse and repeat for the others.
You could also skip the lathe part completely if you have something to accurately mark a horizontal line across the center of the part directly onto the part as it is in the vice. Something like a height gauge or surface gauge or an adjustable parallel.
Indexing 8 is as simple as just indexing 4 (easy to do with a square) - then splitting one of the segments and indexing 4 again.
Indexing 6 - just grab something hexagonal and attach it to the end of the part. Like the rose index it doesn't even have to be centered as its only the angles you're interested in. Then split one of the segments and repeat if you want 12 etc.
15th Nov 2021, 06:35 PM #8Most Valued Member
I highly recommend drilling 12 or 24 holes in your chuck's back plate and fitting a tapered locking pin somewhere on the lathe.
Especially handy if you have a toolpost mounted motor with ER11 collet chuck.Chris
15th Nov 2021, 09:22 PM #9Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Thanks to everyone who posted - there are many ways to skin this cat! I was having a real mental block and I know it wasn’t a particularly hard problem, I just needed some ideas to get me thinking how I could do it. I really enjoy the forum and the helpful posts here just show what a great bunch of people are willing to share helpful advice. I think I have a decent way forward now and hope to share my setup and results later in the week.
Ian
15th Nov 2021, 09:24 PM #10Senior Member
- Feb 2012
- Tamworth, NSW
- 205
15th Nov 2021, 10:01 PM #11Most Valued Member
It’s one of these.
https://www.banggood.com/Machifit-ER11-Chuck-CNC-500W-Spindle-Motor-with-52mm-Clamps-and-Power-Supply-Speed-Governor-p-1027937.html?imageAb=2&gmcCountry=AU¤cy=AUD&createTmp=1&utm_source=googleshopping&utm_medium=cpc_union&utm_content=2zou&utm_campaign=ssc-au-all&gclid=EAIaIQobChMItef7s8C83wIVxRwrCh1jcwyeEAQYASABEgJRXvD_BwE&cur_warehouse=CN&akmClientCountry=AU
Great for drilling and milling with bits up to 6mm. Probably good for grinding too, but I don’t like getting abrasive grit on my lathe.Chris
16th Nov 2021, 06:04 AM #12Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
I also have something similar:
My toolmaker neighbour machined up the holder for me.
I initially used it for milling slots in a faceplate:
but setup was not rigid enough (8mm HSS cutter in cast iron). A smaller milling cutter might work better.
I have since used it for grinding, which was a little more useful.
16th Nov 2021, 06:31 AM #13Most Valued Member
16th Nov 2021, 07:22 AM #14Diamond Member
- Aug 2019
- 1,196
Got a cheap oversized collet from here:
https://www.aliexpress.com/item/32947049504.html
(which reminds me - I should buy some oversized ones for my ER32 holders, but they aren't cheap:
https://www.aliexpress.com/item/1005001836996758.html
22nd Nov 2021, 11:12 AM #15Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Just a quick update on this. I used a large nut that screwed into a plug that sat nicely in the end of my bar. A threaded rod acted like a draw bar through the round stock keeping the nut securely in place. From there it was a simple case of using a 1-2-3 block to index the flat of the nut to get 6 index points for the 6 flutes. Hopefully the pics show this and all worked very well. The flutes are not particularly deep but are just right for the purpose of giving some hand holding grip. Now just a couple of grub screws need to be drilled and tapped and I will have my finished tap and die holder for my tail stock. Thanks to everyone for their suggestions on this topic.
Aluminium round stock
By Michael G in forum WANTED TO BUYReplies: 4Last Post: 1st May 2021, 04:19 PM -
Looking for some Bronze Round stock
By Frank Courtney in forum WANTED TO BUYReplies: 3Last Post: 15th Nov 2019, 10:21 PM -
Suppliers not holding stock
By Mike4 in forum GENERAL DISCUSSION / OFF TOPICReplies: 8Last Post: 9th Jan 2016, 01:03 PM -
Holding rough stock
By morrisman in forum TIPS, TRICKS & HOW TO'SReplies: 1Last Post: 13th Dec 2013, 09:01 AM -
Ideas for work holding small round parts
By variant22 in forum METALWORK GENERALReplies: 27Last Post: 26th Aug 2013, 10:43 PM
