Results 1 to 15 of 20
Thread: Machining in Southern Asia
12th Nov 2021, 06:02 PM #1
These guys are amazing - and it is all done with basic tooling. The chips are flying: it looks like a cast iron crankshaft ? https://www.youtube.com/watch?v=-inYCr-fV3Q
Then again. I have bought a Indian made clone of a Lister CS engine and the two keyways machined in the crankshaft for the flywheels were way out of alignment, and so were the flywheel keyways - very badly misaligned. I had to make up bespoke gib keys which I could never get to fit 100% correctly. The camshaft setup needed a few mods, others have written all this up in various forums dealing with Indian made Listeroid engines.
The cranks in the video are for a Massey Ferguson tractor 3 cylinder Perkins engine. https://www.ebay.com.au/itm/38307589...SABEgJQaPD_BwE
12th Nov 2021, 11:00 PM #2Most Valued Member
Thanks for the video link MM, a very interesting documentary. The building is something else, not what I thought it would be like.
13th Nov 2021, 09:30 AM #3
I am not surprised when you consider the step on the factory video where the keyways were cut on the Cincinatti mill.
The operator used a carpenter square off the bed and edge diameter of the journal spigot and used outside calipers to check for checking the equidistant dimensions. A chance of a lump of swarf under square to bed interface, so the measurement would be thrown off.
13th Nov 2021, 09:31 AM #4Most Valued Member
- 2,673
Thanks.
Aside from the cringeworthy safety side (would make a good example vid for training) I thought it was a good example of machining process order etc.
13th Nov 2021, 02:56 PM #5China
- Dec 2005
- South Australia
- 1,658
I clearly have a different definition of "amazing".
13th Nov 2021, 03:55 PM #6Golden Member
- Apr 2018
- Drouin Vic
- 635
Amazing what can be achieved without those pesky OH&S people constantly peering over your shoulder! And that factory appears to possess not just one, but two, actual dial gauges!
13th Nov 2021, 04:57 PM #7Diamond Member
- Sydney, NSW
- 1,249
Interesting video. I really feel like sending them a box of safety glasses. I don't think all that graphite (I think it is) that's smeared over the hands of the lathe operator in Step 2 would be good for you long term.
Ben.
13th Nov 2021, 07:04 PM #8Diamond Member
- Mar 2014
- South of Adelaide
- 1,229
13th Nov 2021, 09:03 PM #9
Metallurgy
I would like to know what the grade of alloy is the cranks are cast with - for all we know it could be recycled engine blocks, whatever it is it appears to machine easily.
There must be a great number of old MF tractors still in use to justify the effort of making new crankshafts but I guess the guys who are actually making them in that video are not paid that well.
New WW2 Jeep engine blocks are being cast in China , reports indicate the new blocks are somewhat less than ideal and quite a bit of remedial work needs to be done to make them useable.
14th Nov 2021, 09:56 AM #10Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
The video (the uploader has several more) shows the reality of life and machining in that part of the world.
I'm not going to have smug sneer at their practices from the comfort of a first world country.
14th Nov 2021, 10:16 AM #11Most Valued Member
- 4,258
can anyone explain to me how the "dial indicator" (hahaha) works in step 2?
14th Nov 2021, 10:49 AM #12Most Valued Member
- 2,673
Just a visual indicator - if the gap at the end doesn’t change or the end come off the part the it’s running concentric.
All a typical dial indicator does is magnify that change, but those old gauges are fine for a rough setup and I believe were quite common back in early 20th century.
14th Nov 2021, 01:07 PM #13
Yes
Yes very true. And those chaps don't stand around talking that much, it is flat out work . They probably get paid on a piece rate , the more you produce the more you are paid which would be a fraction of the amount we would be paid here. When you think about it, as recently as the 1940s many factories in Britain were not health and safety conscious even employing 14 year old kids in highly hazardous work- 14 year old kids in coal mines was common.
15th Nov 2021, 12:02 AM #14Golden Member
- Apr 2018
- Drouin Vic
- 635
Yes smug sneering is easy for sure, but those men are working very hard in difficult conditions and no doubt serious injuries are common; however is also shows why a product built that way is never going to be comparable in quality to one built in modern facilities with modern equipment. Worth bearing in mind when we complain about the cost of stuff made here.
15th Nov 2021, 08:17 AM #15Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Many things there amused me;
- First lathe operator used 2 "safety features."
A little bit of cardboard on the back of the toolpost to stop chips flying into his face,
and a rag to remove the tailstock drill/centre after machining (hot metal?) - Second lathe operator took tools in and out of 4way toolpost quite a few times.
Instead of leaving two in there permanently and rotating it around! - Second lathe operator used verniers as go/no-go diameter gauge,
to see if journals were close to finished size.
I'm guessing the cross slide graduations are too covered in cast iron chips to read - Lathe chucks on the drill presses. Never seen that before!
- Tapping at "full speed" without a fancy clutch/reversing tapping head.
- Grinding cast seams off the crank - angle grinder actually still had a guard fitted!
And, a number of jawless lathe chucks on his bench, used as heavy bases to put the crank in for grinding. - Shot peening machine looks positively modern.
- Horiz. mill cutting the keyway. Shaft and cutter were visibly wobbling around.
- Coolant in the crankshaft grinder!
(and a younger worker to load/unload the cranks) - Video is sped up a lot.
41 minutes would be over 70 (and no-one would watch it?) if shown at actual speed.
I wonder if there is a cast iron (rough steel) foundry on the other side of one of those walls?
Ex Hercus "Asia Planer"
By rickw72 in forum THE HERCUS AREAReplies: 2Last Post: 22nd Apr 2014, 06:34 PM -
Basic machining courses in Southern Melbourne?
By Zarniwoop in forum METALWORK GENERALReplies: 1Last Post: 8th Sep 2007, 02:24 PM
