Results 1 to 4 of 4
Thread: Tailstock Alignment
31st Oct 2021, 11:48 AM #1Most Valued Member
- 5,945
Tailstock Alignment
I have a new AL50G from H&F that has a problem with the tailstock alignment. It has a taper to it, I discovered the problem when I wanted to drill a hole in a roller bushing to make a jig. It was bought through a third party.
When the dead centres are installed, it lines up within tolerance, but when I installed a drill chuck and a 16mm drill bit, (approx 200mm total length from the sleeve) it was about 12-13 mm off centre.
I did rotate the chuck and bit to several places to try and overcome the problem, thinking it was a combination of the two, but it was still there.
To get around the problem initially, I adjusted the tailstock so that the bit was on centre, but would like to fix it properly,
Has anyone come across this problem before???
Thanks,
31st Oct 2021, 12:06 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
wind the quill of the tailstock out, mount a indicator to the carriage and check that the quill is parallel.
31st Oct 2021, 01:39 PM #3Most Valued Member
- 4,887
Based on your length dimension, it would seem if using a dead centre in the Tailstock with the quill wound out the centres between headstock and Tailstock should be out by around 2 mm.
31st Oct 2021, 03:47 PM #4Most Valued Member
- 5,945
Thanks snapatap and pipeclay for that info, didn't check that out, but will do now.
Hercus 260 tailstock vertical alignment
By futnuh in forum THE HERCUS AREAReplies: 6Last Post: 4th Nov 2021, 03:10 PM -
Tailstock Alignment - A Revisit
By Anorak Bob in forum METALWORK GENERALReplies: 5Last Post: 30th Jun 2013, 10:38 PM -
Simple Tailstock Alignment Check
By electrosteam in forum METALWORK GENERALReplies: 1Last Post: 5th Apr 2012, 11:03 PM -
Tailstock Alignment Puzzle
By Bryan in forum METALWORK GENERALReplies: 45Last Post: 5th Oct 2011, 11:00 PM -
Lathe headstock and tailstock are out of alignment
By 19brendan81 in forum METALWORK GENERALReplies: 24Last Post: 22nd Nov 2010, 03:00 PM
