Results 1 to 9 of 9
Thread: How to bend thin flat brass bar
27th Oct 2021, 07:54 PM #1New Member
- May 2009
- Townsville, Nth Qld
- 3
Hello, my first posting here, being a woodworker, metal work is a black art.
I have a piece of flat brass bar 1" x 1/16" 300mm long that I want to bend at right angles about 4 inches apart. I need this bend to be pretty sharp.
What is the best way to do this? If heat is required, would a heat gun be adequate? Waht is the best wasy to grip the metal to turn it , etc
Kind regards to all,
Dengueregards,
Dengy
28th Oct 2021, 11:28 AM #2Golden Member
- Dec 2007
- 574
My experience with brass on model steam engines tells me you would anneal the brass first - I have never tried a heat gun but I doubt it is good enough, you need a flame like a propane torch, stove top or even a cooks blow torch that is used for melting sugar on fancy deserts - get it good and hot and dunk it in water and bend it cold. While you don't need a folder to bend it, to get a good sharp bend you really need a folder. Before I had a folder I would clamp the annealed brass in the vice and using a bit of hardwood push and bend the brass as close to the vice jaws as possible, as the bend gets closer to 90deg you can try some persuasion with a hammer working as close to the vice jaws as you can. The brass work hardens as you bend it and you may want to bend it half way and then re-anneal before finishing the bend I have done this when forming boiler ends - get it part way - re-anneal and then finish it. If you need the brass to have a good surface finish a pair of hardwood vice jaws helps prevent marks on the brass.
28th Oct 2021, 03:28 PM #3
Corners
If I need a very sharp corner in flat bar I cut the bar half way through and the bar will naturally bend along the cut. I then solder, weld or braze fill the outside corner notch and file it square. The deeper you make the cut the sharper the corner will be. Maybe that method isn't suitable for you , it depends on if its a decorative item or not.
28th Oct 2021, 06:12 PM #4Most Valued Member
28th Oct 2021, 11:28 PM #5New Member
- May 2009
- 3
29th Oct 2021, 09:20 AM #6Golden Member
- Dec 2007
- 574
Discoloured brass is easily polished - good old Brasso/Silvo if you have it or AutoSol used for polishing mag wheels, anything similar - I should mention if you need to used a hammer to on the brass to get a sharp bend then do not hammer the brass directly, it will show the hammer marks - use a block of wood against the brass.
29th Oct 2021, 09:50 AM #7New Member
- May 2009
- 3
Thanks for the comments above about polishing annealed brass. Have both Brasso and Autosol, used to polish chisels to make them look pretty
Found my Wagner heat gun will only get to 590degC. Would this be adequate to anneal brass, or do I need something with a flame?
also, I understand this annealing process softens the metal, allowing it to bend without damage.
Once the annealing and bending is finished, how do you treat the metal to return its hardness and strength?regards,
Dengy
29th Oct 2021, 11:06 AM #8Golden Member
- Dec 2007
- 574
Not sure if the heat gun is up to it, there is probably some info online giving temp required to anneal brass, do a search - once annealed you will feel the difference compared to non annealed metal when you try to bend it by hand - you will also feel it getting harder as you bend it and it work hardens, I guess the best way to see if a heat gun is up to it is to try it - be interesting to see if it is. Brass is not really a hard material the action of bending it usually returns it back to it's original strength - I have always just left it once it is bent how I want. Try some scrap material - anneal it and bend back and forth you can feel it getting harder - it only takes a few times and it feels like it not annealed any more. Do a you tube search I'm sure there are plenty of videos out there that give lots of info.
9th Nov 2021, 05:22 PM #9New Member
- Dec 2019
- Auckland
- 1
Unclebarry
There are many types of brass some bend and some break ask uncle Google to tell u more
Tonnage required to bend Flat Bar Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 3rd Jan 2021, 04:02 PM -
what rods for thin brass to brass ??
By Mathuranatha in forum WELDINGReplies: 7Last Post: 23rd Nov 2020, 08:17 PM -
Milling large flat thin pieces
By j3dprints in forum METALWORK GENERALReplies: 5Last Post: 9th Sep 2017, 05:35 PM -
Need someone to bend Flat Steel Bar in Melbourne
By jk200sx in forum METALWORK GENERALReplies: 3Last Post: 20th Apr 2016, 10:39 PM -
VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
By thumbsucker in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 18th Mar 2013, 03:36 PM
