Results 1 to 8 of 8
    Dec 2005
    South Australia
    1,657
    Default Forward/ reverse switch
    Hi, I need to replace the switch on my, old generic mill, "currently just on off" is there any advantage of making it forward/reverse other than tapping.
    Sep 2006
    Australind , WA
    58
    1,281
    I have never needed reverse on my HM-45, but I don't use it that much. I have to make sure I select forward every time.
    Can't think of a need for reverse.....
    6,473
    Hi Bob, Guys,
    I have reverse on my mill ! Its very handy for tapping, but if you are slitting something it good to be able to turn the saw over, reverse direction and slit from the other end/side.
    But any other suggestions would be handy for using reverse !
    Jun 2005
    Townsville, Tropical Nth Qld.
    226
    China, the first thing you have to find out is if the motor can be made to reverse easily. If it's single phase it could be easy or nearly impossible. Three phase generally easier. You may need to take it to a motor rewinding shop to find out.
    Rgds,
    Crocy.
    Dec 2005
    South Australia
    1,657
    Thanks for the suggestions, I will probably go F/R as as if I haven't got it I can't use it, it is 3Ph I have mate who is a sparky he will sort out if it is reversible or not, he does all my wiring.
    Nov 2007
    melbourne australia
    3,228
    If it’s 3 phase it’s reversible. He just needs to wire it so the reverse position of the switch swaps any two of the phases.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    ...but if you are slitting something it good to be able to turn the saw over, reverse direction and slit from the other end/side.
    About the only thing I use reverse for I think.
    Feb 2013
    Laidley, SE Qld
    1,039
    I use the reverse function on my HM52 when I'm power tapping.
    Not what you asked but a cautionary tale about wiring a reversing switch.
    A while ago the HM52's motor died and I replaced it with a good Italian motor.
    How hard could it be to figure out how to connect the existing switch wiring to the new motor's terminals?
    I ended up taking the new motor and the old switch to an electrician who understands such things.
  1. forward / reverse motor wiring
    By hpa1 in forum ELECTRICALS
    Last Post: 13th Jan 2021, 02:04 AM
  2. reverse/ forward on mill
    By China in forum METALWORK GENERAL
    Last Post: 3rd Feb 2020, 09:30 PM
  3. Replies: 0
    Last Post: 25th Mar 2018, 06:58 PM
  4. SOLD: 415v motor with forward reverse
    By Ch4iS in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 19th Apr 2012, 09:42 AM
