Results 1 to 8 of 8
    Tennant Creek, Aust
    61
    601
    Default How to Hold This?
    I have this piece of aluminium 140 x 20mm
    That I would like to if possible to cut out the 70mm centre so I can use it later.
    My problem is that I don’t have a chuck large enough, is any I hold it on a 9 x 20 lathe?
    Aug 2011
    4,779
    Mount on a face plate and trepan it?
    Or mount on a rotary table and gang drill using 5mm drill bit.
    Or, measure out, centre punch and drill on a drill press. Then use a jig saw.
    Sent from a galaxy far far away
    Jun 2007
    Vic
    48
    544
    how about holesaw?
    I have done 1" thick with holesaw before
    Oct 2008
    N.W.Tasmania
    1,407
    If you don't have a faceplate, you could always mount as large as reasonably possible stub of round bar, or even a chunky piece of plate into the largest chuck that you have, face it off and then use cyanoacrylate adhesive to mount your aluminium workpiece. If trepanning you could use the tailstock for support, or if using a holesaw, obviously that is not so easy to arrange additional support, but the holesaw itself becomes the support at the cost of "the dump" being left with a hole in it. Good luck.
    Nov 2007
    melbourne australia
    3,228
    So the 70mm centre piece is the waste that you want to keep for a future project? What operations do you want to perform on the resulting ring after removing the centre?
    Mar 2011
    Southern Flinders Ranges
    1,555
    Holesaw in a drill press/mill or chuck it in a four jaw and holesaw in the tailstock if you can clear the jaws.
    Could also drill a small hole and cut the centre out with a scrolling blade in a jigsaw.
    Tennant Creek, Aust
    61
    601
    Thanks for your replies every one, I never thought of using hole saws to cut that deep.
    My plan is to make a holder for a LED ring light to mount on my drill
    I used a hole saw took a while but got through OK.
    Nov 2017
    Geelong, Australia
    57
    2,673
    Good tip with using a holesaw on thick material is to drill one or more smaller holes that the holesaw teeth will cut into. Helps to clear the swarf out of the gullets of the teeth.
  1. How would you hold this?
    By andrew_mx83 in forum METALWORK GENERAL
    Last Post: 8th Jan 2014, 03:49 PM
  2. what to hold wood with in headstock?
    By turbo TA in forum METALWORK GENERAL
    Last Post: 3rd Nov 2009, 01:50 PM
  3. How to hold a rod
    By phelum in forum WELDING
    Last Post: 1st Apr 2008, 02:14 PM
  4. Will solder hold?
    By Brickie in forum METALWORK GENERAL
    Last Post: 31st Dec 2007, 04:14 PM
