Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
  1. #31
    May 2012
    Dandenong
    76
    When I started looking for a larger mill than my Vario BF16, I settled on the DM45 as it was probably the best of the breed at the time for that class machine.
    I ended up getting a large knee mill (similar to H&F HM52) with NT40 instead. R8 is a massive improvement over MT(anything), but if you can get a variant with NT30 you'd be much happier, even if it set you back a little more.
    For the size the DM45 is, a geared head will be perfectly fine, but I made the mistake with my large mill of getting a geared head. The bigger the mill the louder the gears are in use. Just something to keep in mind.
  2. #32
    Jul 2008
    near Warragul, Victoria
    3,718
    Default Blueprint
    Would it be possible to ' blueprint' the gearbox of a 45 drill/mill in order to quieten it down and at the same time reduce the associated vibrations ?
  3. #33
    Mar 2011
    Southern Flinders Ranges
    1,536
    Probably, but the amount of fettling required would be a significant project likely requiring most of the drive assembly to be remade, shimmed, bushed or modified in some way, inc the housing itself. From the research I’ve done on it, it seems the most common solutions are either to live with it or do a DC motor and belt drive conversion (which aside from making it quieter gives you speed control via the controller and usually increases the highest speed into a more carbide friendly range)
  4. #34
    Feb 2018
    Sydney
    33
    Question
    Sparkie, please give us an update on your mill ��
    I've been looking at options and the Metex 45 is on the shortlist.
    Frank
  5. #35
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,541
    His profile says that he has not been active since Jan 17th this year. You might be better off sending him a PM asking that question, or to attract his attention.
  1. Mill stands for a RF45 - Metex, H&F ?
    By takai in forum METALWORK GENERAL
    Last Post: 16th Mar 2020, 06:18 PM
  2. Where to buy DM45/46 Mill with R8 spindle?
    Last Post: 27th Aug 2012, 11:01 PM
  3. Converting a DM45 Mill to 3phase EVS
    By Big Shed in forum METALWORK GENERAL
    Last Post: 3rd Sep 2011, 07:33 PM
  4. New DM45 mill
    Last Post: 6th Feb 2011, 04:34 PM
  5. Standaco's DM45 Mill/Drill ?
    By steran50 in forum METALWORK GENERAL
    Last Post: 8th Jan 2009, 08:23 PM
