Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Sep 2021
    Melbourne, VIC
    5
    Default Damaged Threaded Shaft - Rethreading?
    I have a threaded shaft with damage meaning the corresponding nut won't engage. I think it is just the top and one-two starting threads that are damaged.
    Pics below.
    It's about 14mm across (might be imperial) and most die sets I can find stop at M12. Never tried cutting new thread before and am a bit reluctant to have a first go at something I can't easily find a replacement for.
    I've called a few engineering shops I can find and some might be able to assist by machining new thread.
    Does it looks like something I could DIY with something I'm missing, or do a need a new one machined?
    IMG_20211011_101008.jpgIMG_20211011_100942.jpgIMG_20211011_100911.jpgIMG_20211011_100846.jpg
    7,189
    If you have access to a belt sander or finisher I would try carefully grind a bevel on the end of the treaded shaft that grinds away the damaged threads.
    Sep 2008
    Riddells Creek, Vic.
    838
    This is the type of job where a Thread File is invaluable,
    Apr 2007
    Newcastle
    229
    I did a very similar repair using a thread file. A slight deformation on the lead in made it impossible to start a die with any confidence.
    Sep 2021
    Melbourne, VIC
    5
    Yes Bob - Do have a standard GMC belt/disk sander.
    Right, could just slowly bring the very tip to the side of the belt and try to grind away just the 1st/2nd thread and try not to hit the next
    Yes - Had seen a thread file, but thought the damage might have been too much. Or difficult if it is imperial
    Tried the smallest triangle file I had, felt I still might have been hitting the thread below. Could be technique
    Hmm, not a lot of thread there to practice on!
    Mar 2011
    Southern Flinders Ranges
    1,555
    A small triangle file and half a beers worth of filing will guarantee you dont hit the next thread...
    7,189
    Quote Originally Posted by FlaminGunz View Post
    It doesn't matter if you hit the next thread or even 2 with the sander or the file.
    When I cut bolts with a thin kerf cut off saw,. if I remember I put a nut on below the cut, then when it's cut I take the burr off by removing the nut.
    BUT
    I usually forget to put the nut on before cutting so then I use the Linisher with a fine grit paper and round over the end. My cut off wheel and Linisher are on the same grinder so I literally move it from one to the other.
    For awkward situations where its difficult to get the nut started I sometimes grind a 2-4 thread long taper on the end of the bolt to help the nut find the tip of the bolt. I've never had a problem with cross threading doing this.
    6,480
    Needle files often have a fine thread file in the set, ideal for correcting damaged threads !
    Sep 2008
    838
    The problem with butchered shafts like this is that it is not only the Major diameter of the thread that is "mushroomed" slightly, but also the minor diameter, so cleaning up the O/D may not be enough to get the nut started.
    Feb 2014
    Werribee, Melbourne
    178
    What is the diameter of the thicker section of the shaft?
    If it is less than 26mm (the spindle hole size of my operational lathe) and you can wait until we are let out of detention in metro Melbourne (hopefully only a few weeks away), I would be happy to see how well it would clean up on the lathe by picking up on the good part of the thread.
    That should also clean up any minor diameter issues mentioned by Techo1.
    Jul 2008
    Sydney Australia
    142
    I would first try using a split die if i had one of the correct thread.
    Jun 2007
    Vic
    48
    544
    I am in Mount Waverley and I can help if you are not too far from me? Maybe it is better off to put on highest speed then spin the chuck by hand.
    Jan 2004
    Mackay North Qld
    6,446
    Pics below.
    Hi FlaminGunz
    If you are having difficulty in identifying that your thread is metric or imperial, the best way might be to take it to a dedicated fastener supplier. By dedicated , I mean that nuts and and bolts are their main product/s.They often carry single dies- I don't know about the die nuts.Probably a enginneering tools shop might be the best place to look for them
    They have tools to measure thread pitch and diameter and will happily identify your mystery thread and sell you a die nut or even a die if it comes to that.
    Apart from the problem of getting there- lockdown?? there is are other snags in this plan.
    A die nut is a hex shape and is used to repair damaged thread -not to cut a new thread from a bare steel shaft. You can use a shifter to turn it.
    However,there is also a round die nut , sometimes referred to as a thread chaser and has to be held in a decently strong die wrench, so that is an extra expense. Note that it has no split in it unlike the threading dies in your set. Pics below of both types.
    You may think you might buy the same die diameter as your existing set. While the die may fit the circular aperture of the smaller wrench ,the wrench may be too small across the handles to have effective leverage. Some of these die wrench handles are made from die cast zinc and are not very robust.
    I take it that the shaft is not too heavy to carry around. You could take the nut instead. I am pretty sure they should be able to ID that .
    If you can get it to one of the fastener shops they at least can tell you what the thread is, even if the don't have a die to sell you.
    The lads here can advise you on a local engineering tool shop once you get a id on the thread.
    Does this help?
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    There are also square ones:
  15. #15
    Sep 2021
    Melbourne, VIC
    5
    Just an update - success!
    Pics - https://imgur.com/a/mW8HmYN
    I ended up taking BobL's advice as it was the simplest with the tools I have available.
    Now just need to sort out putting the tablesaw back together
    Thanks all for the tips and offers of assistance, will keep in mind next time I am inevitably stuck.
  1. I think i damaged my compound..........
    By Zumanity in forum THE HERCUS AREA
    Last Post: 5th Aug 2019, 05:35 PM
  2. Rethreading stub axle.
    By clear out in forum METALWORK GENERAL
    Last Post: 12th Oct 2018, 10:35 PM
  3. Rethreading and repairing a scrap muzzle loader.
    By aametalmaster in forum GUNSMITHING
    Last Post: 25th Sep 2014, 07:36 PM
  4. Replies: 8
    Last Post: 1st Sep 2014, 12:26 PM
  5. Oops! May have damaged something!
    By bwal74 in forum THE HERCUS AREA
    Last Post: 30th Sep 2012, 06:33 PM
