Results 1 to 8 of 8
5th Oct 2021, 05:56 PM #1Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
Help needed to identify these parts
I've got 4 sets of these blocks with the only identifying marks being CU350, CU400, CU500 & CU650. They have mirror polished hexagonal sections of various sizes in the centre section ... hence the different numbers. My theory is some sort of hammer mill maybe.DSCN1252.jpgDSCN1251.jpg
The other piece looks like it goes in a lathe tool post and has a universal type joint with a collet for holding the shafts which also screw together. This one I'm really lost on.DSCN1253.jpgDSCN1254.jpg
5th Oct 2021, 06:14 PM #2
5th Oct 2021, 06:58 PM #3Senior Member
- May 2019
- 77
- 312
Thank you Rick ... obvious really but it's pretty serious cable they'll be used on.
Now for the other little trinket.
5th Oct 2021, 07:14 PM #4Most Valued Member
- 70
- 1,511
5th Oct 2021, 07:39 PM #5Senior Member
- Jan 2012
- 149
Second thing is a gimbal type lathe center finder.
Google: Starrett Number 65 Center Tester.
5th Oct 2021, 10:29 PM #6Senior Member
- May 2019
- 77
- 312
8th Oct 2021, 03:34 PM #7Senior Member
- May 2019
- 77
- 312
Here's another strange one I found in the cleanup. I know what it is now but without the bits that screw to the jaws I couldn't figure it out. This tool has a 1" dia spigot so I'd say it's spent a lot of it's life in a turret lathe.DSCN1283.jpgDSCN1284.jpg
10th Oct 2021, 10:08 PM #8Most Valued Member
- Jul 2016
- 35
- 1,522
I think that last item might be a cut knurler, if you need wheels for it i have bought them from Millers tooling in qld (zeus brand) but they will only work if its a 15 degree angle on those end faces.
Can anyone identify this for me please?
By graham.beven in forum METALWORK GENERALReplies: 2Last Post: 12th May 2021, 07:44 PM -
Identify this bar stock
By monchochos in forum METALWORK GENERALReplies: 10Last Post: 29th Jul 2017, 12:46 AM -
AL-960B owners needed, herless lathe interchagable parts???
By brendanh in forum METALWORK GENERALReplies: 24Last Post: 9th Feb 2015, 06:55 PM -
Waldown radial drill - parts needed.
By richo132 in forum METALWORK GENERALReplies: 38Last Post: 28th Feb 2012, 06:30 PM
