Results 1 to 9 of 9
4th Oct 2021, 08:56 PM #1Intermediate Member
- May 2020
- australia
- 62
- 33
How to keep concentricity when working on both ends of a round bar
I have spent the whole afternoon making a die holder for the lathe. First the round bar was clamped in a 3 jaw chuck. I worked on one end and then flip around and do the other end. However, I can tell both side don't seem to be concentric. It's off by a few mm. Should I do one end. The other end needs to be clamped by a 4 jaw and dial in to keep concentricity?
One more question, the biggest drill size is 13mm from my drill set. However, 13mm hole could not fit in drilling bar, can I still use the bore to drill out a bigger hole. A large size drill bit costs a lot money, I am not sure whether it is very needed. If it is needed, 16mm drill size is the minimum in order to fit the boring bar.
4th Oct 2021, 09:12 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Depending on the level of accuracy you are working to dialling it into a four jaw is the optimal solution. You can also put a dial on your material and tap it around in the three jaw.
If it’s mm out that suggests your stock was probably out of round before you started, I see that regularly when I use recycled or hot rolled.
You can make a smaller boring bar relatively easily with a piece of round stock, a grub screw and drill bit regrouped as a cutting edge. Or buy one, or buy a bigger drill bit. Thousand ways to skin that cat
4th Oct 2021, 09:20 PM #3Gear expert in training
- 34
- 1,079
There ya go, cheap morse taper drills https://mcjing.com.au/morse-taper-shank-drill-bit.html
4th Oct 2021, 09:34 PM #4Intermediate Member
- Aug 2020
- Cowaramup WA
- 28
You could make a smaller Boring Bar. They are quite simple to make, there are many examples to be found with a google search. It's a reasonably quick project, you'll learn something new and have a tool you can use for other projects. Making tools to make tools to make something else is all part and parcel of this hobby...
Dave.
4th Oct 2021, 10:39 PM #5Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
1) A few mm out seems quite bad. It could be the material you are grabbing, or maybe the lathe's chuck/jaws. Did you try to check the material concentricity (in the chuck) with a dial indicator before turning it down?
2) Yes, a 16mm drill is not cheap, and your lathe might have trouble drilling a hole that large.
A smaller boring tool or bar might be more useful.
4th Oct 2021, 11:33 PM #6
If I need a hole bigger than 12 mm in a workpiece, then a boring bar is my first choice.
Actually I often find that my normal lathe tool turned to face the chuck is fine for larger holes.Best Regards:
5th Oct 2021, 11:06 AM #7Most Valued Member
Depending on just how close you want to get and how much material you have, turning between centers is one way to fix your problem but possibly a little OTT for a dia holder.
7th Oct 2021, 12:16 PM #8Senior Member
- Sep 2009
- Newcastle
- 342
A few millimetres is a lot.
Get a bit of scrap about 60mm long (long enough that more than half sticks out from the chuck when fully gripped in jaws)
Face the first end
Turn down half the length to a known diameter.
Take out of chuck, flip.
Face second end
Turn down the second half / slightly more than half the length (turned areas need to meet) to the same diameter.
That will show the runout.
Make sure the 3 jaws meet properly in the middle. It is possible to have one jaw too far in or out (on the wrong part of the scroll)
7th Oct 2021, 01:41 PM #9Member: Blue and white apron brigade
- 7,188
Turning shallow domes on the ends of 316 SS round stock
By bob ward in forum METALWORK GENERALReplies: 10Last Post: 10th Nov 2019, 07:46 PM -
Rounding key ends
By bob ward in forum METALWORK GENERALReplies: 15Last Post: 31st Oct 2018, 07:11 AM -
odds and ends (junk)
By dodge at4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 23rd Mar 2018, 10:28 PM -
Flush fit for ball ends
By Tiger in forum METALWORK GENERALReplies: 12Last Post: 8th Apr 2010, 11:13 AM -
squaring the ends
By tanii51 in forum METALWORK GENERALReplies: 2Last Post: 17th Sep 2009, 09:42 AM
