Results 1 to 8 of 8
Thread: waterjet cutting a certain shape
4th Oct 2021, 07:04 PM #1Intermediate Member
- Jun 2021
- worldwideweb
- 27
Hello! I am interested if you think it is possible to waterjet cut an edge as shown in the images using 5-axis machine (omax 80x). The green triangle part is apparently problematic.
Thank you for your answers
4th Oct 2021, 07:57 PM #2Gear expert in training
- 34
- 1,079
Absolutely no waterjet knowledge, but my first instinct is that the sharp internal corner is an issue because the jet will be stationary at one point while it tips the head which might end up blowing out the corner.
Could you modify it slightly to blend the 45 degree edge smoothly into 90 degrees as it comes around the corner?Gear cutting specialists and general engineers www.hardmanbros.com.au
4th Oct 2021, 09:04 PM #3Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Can be done, you’ll need to find somewhere that has a machine with the ability to rotate the cutting nozzle to an angle.
Assuming the return on the bottom is part of the same assembly, that will need to be made separately and either bolted or welded on.
4th Oct 2021, 10:04 PM #4
Not a good idea for ground engaging equipment.
What is shown is two flat planes intersecting to an internal corner, finishing with a sharp edge.
It screams out to me " cracks start from here".
That is not an if its going to break type statement, but a when.
Never put a stress raiser in an internal corner (as per your illustration)
Irrespective of the process you cut it with, do not leave the finished item like that . Probably some weld fill should be applied as well to improve the sweep of the radius.
With a disk ,then a flap wheel, blend those two flat planes smoothly into one another.
I spent my apprentice ship in building the accoutrements for earth moving equipment and crack repair on the same.
4th Oct 2021, 10:05 PM #5Intermediate Member
- Jun 2021
- worldwideweb
- 27
Yeah, that sharp internal corner is apparently problematic. I do not understand why it can't be done in 2 passes. For exaple, in the first pass a sharp edge is created going from bottom to the top. In the second pass, the machine stops the water flow, keeps the sam tilted angle, moves to side and makes another pass horizontally up to the end of the problematic triangle.
Most probably I'll go with blending the sharp edge smoothly into 90 degrees. If would be a challenge to draw such geometry in solidworks.
4th Oct 2021, 10:25 PM #6Intermediate Member
- Jun 2021
- worldwideweb
- 27
5th Oct 2021, 10:37 AM #7Senior Member
- Oct 2010
- NSW
- 181
I've never used Solidworks and I've never done anything like this in Turbocad before, but just did this easily so Solidworks should handle it no problem.
5th Oct 2021, 04:24 PM #8Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Even relatively small stress raisers can have big implications.
In the Late 90's a well known maker of heavy trucks made a change to the 20mm thick plates on the ends of the crossmember that supported the rear of the cab. Trucks that had been in service for well under 6 months began returning to the dealership with these plates cracked through and both the cab and crossmember floating around in the breeze. What was the change that brought this about? Simply changing from flame cut plates to plates punched or sheared with the resultant scratches and gouges in the edges that allowed cracks to propagate. That was one of the best lessons that I ever learned as an apprentice. Smooth lines and smooth transitions make for a smooth life.
Plasma cutting capacity or waterjet cutting connections?
By jhovel in forum METALWORK GENERALReplies: 25Last Post: 4th Apr 2014, 11:06 AM -
fly cutter tool shape
By morrisman in forum METALWORK GENERALReplies: 24Last Post: 9th Feb 2012, 05:06 PM -
Turning tool shape
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 14th Oct 2011, 07:49 AM -
Waterjet Art
By scotty60 in forum METALWORK GENERALReplies: 5Last Post: 24th Feb 2010, 09:16 PM -
Milling, Laser Cutting or Waterjet a large object
By mangrovejack in forum METALWORK GENERALReplies: 5Last Post: 29th May 2009, 11:51 PM
