Results 1 to 14 of 14
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,514
    Default Help with part name.
    I can't remember what they are called, but they are pretty much a disc with a type of tooth setup on the face, that only drive one way when two are combined. Pretty poor description but maybe enough for someone to know what I mean.
    Nev.
    near Rockhampton
    6,218
    A ratchet drive? Or an overrunning clutch sort of thing? Dog clutches are positive drives that run both ways.
    Nov 2007
    melbourne australia
    3,228
    Google “ratchet slip clutch” and select images. I think that’s what you’re after.
    Nov 2008
    70
    1,514
    One way ratchet is what I was thinking. Two discs mounted to a shaft with a spring to lock them together in one direction and when reversed it would ratchet freely.
    Nev.
    Nov 2007
    melbourne australia
    3,228
    https://www.ggmfg.com/products/coupl...p-clutches.php
    doesn’t appear to be one-way though.
    6,480
    Hi Chris, Guys,
    No they are not, they are similar in action to the screw driving clutch used on battery operated drills !
    Nov 2008
    70
    1,514
    Here's a link to an Overunning Clutch. -
    https://www.youtube.com/watch?v=gOuLq2haqLY -
    So what I am looking for is pretty much the tooth design on this but instead it will be on the face of the discs rather than on the ID as it is here. I know they exist because I have seen them before but forget their name.
    Nev.
    Nov 2007
    melbourne australia
    3,228
    A kickstart ratchet? https://kzrider.com/forum/2-engine/5...tarter-stopper
    Quote Originally Posted by SurfinNev View Post
    Where have you seen them? In what context?
    Jan 2004
    Mackay North Qld
    6,446
    Escapement , as in watch and clock making ?
    Watch Escapements Diagrams & Pictures
    Dec 2013
    56
    1,418
    What diameter are you after, I'm sure I have a side type of teeth to suit around 40mm
    Sent from my 5007U using Tapatalk
    Using Tapatalk
    Sep 2007
    Wentworth Falls NSW 2782
    77
    134
    Face gear?
    Nov 2008
    70
    1,514
    Sprag clutch is probably closest to what I was thinking of, but still not what I am looking for. Will think of the name in the middle of the night maybe.
    Nev.
    Nov 2008
    70
    1,514
    Stumbled across this during my searches. Maybe of some interest -
    https://cpb-us-w2.wpmucdn.com/sites....d-Linkages.pdf
    Nev.
    Nov 2008
    70
    1,514
    Nordlock Washers seem to be the closest thing yet. The idea was to attach one washer to a lever and the other to a shaft I wish to drive. Lever bolted into end of shaft with a little clearance so it can disengage when reversed. A spring would apply pressure to the lever with the washer fixed to it so it would engage in one direction. I am still sure there was something similar though.
    Nev.
  1. How would you make this part?
    By Pete O in forum METALWORK GENERAL
    Last Post: 10th Feb 2021, 04:26 PM
  2. Casting Tools Part 5 - Casting a part
    By RayG in forum THE FOUNDRY
    Last Post: 30th Jul 2018, 12:46 PM
  3. New Lathe Part 2
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 28th Mar 2016, 09:05 PM
  4. Fiddly part
    By Briangoldcoast in forum METALWORK GENERAL
    Last Post: 30th Jan 2015, 07:07 PM
  5. Screwcutting part 2
    By Kody in forum METALWORK GENERAL
    Last Post: 8th Jan 2009, 12:22 AM
