Results 1 to 7 of 7
Thread: Affix Brass to Weathering Steel?
28th Sep 2021, 08:44 AM #1New Member
- Sep 2021
- Michigan
- 2
If I attach a piece of sheet brass to a larger piece of weathering steel, will I have galvanic corrosion problems between the two metals? Does the joining method matter? I could use cold fastening (bolts, probably also brass) or silver solder.
28th Sep 2021, 08:55 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
By weathering, do you mean there is already rust there?
Many old machines have brass nameplates on corroded steel parts like electric motor housings, seem to hold up OK if not beautifully.
28th Sep 2021, 08:58 AM #3New Member
- Sep 2021
- Michigan
- 2
I mean Cor-ten steel. It forms a protective oxide layer that stops ordinary rusting. Some claim it also insulates so galvanic corrosion isn't an issue, but the oxide layers takes months/years to form. I should have noted that this piece will live outdoors. Good point about brass nameplates.
28th Sep 2021, 09:04 AM #4Mechanical Butcher
- Oct 2004
- 1,894
I've only noticed what looks like stainless steel info plates on Corten containers, but brass might also be used.
You could with some thin rubber gasket etc provide a separation between the metals, that needn't be obvious?
28th Sep 2021, 01:46 PM #5
First up,welcome to the MetalWork Forums.
You joined an Australian based MetalWork Forum so mainly we talk in terms of products and vendors known local to us.
A good bunch of fellas but we talk different ok? Solder is pronounced by us with an L , Solder not Sodder.
What A brass Plaque attached to corten steel
Why To avoid corrosion
How Possibily, silver solder or alternately fasteners
When How long does this have to last?- where it will live is a important factor
Where The environment- is it a salt mine or submerged in an acid?
Who well obviously you ,but do you have the tools and equipment you may need.
The information base needs to be a little bit broader as one facet may affect another.
You will find many like minded folk here with same interests as you.
If you explore our pages you will find bits and pieces of interesting things all over the place.
Go to the FORUM box at top LH corner and click on it.
A drop down menu appears and you can select Forum Home at the top of the drop down menu list. Scan down the pages to look at what we have.
Please make sure read the Terms of Use -our Rules - pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member
Normally the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
Its anti spam thing.
There are all sorts of forums that might be parallel with your interests, found as described above.
If any questions contact me via PM and I'll try to help you.
28th Sep 2021, 06:10 PM #6Senior Member
- Apr 2007
- Newcastle
- 229
To be honest I think you have a very low chance of getting an answer to something as specialised as this on any forum. And even if someone gave me an answer I probably wouldn't trust it. I would talk to the manufacturer's technical support. They will be all over the chemistry of the surface layer.
28th Sep 2021, 07:56 PM #7Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
Brass fasteners would be the best choice, see chart.
what rods for thin brass to brass ??
By Mathuranatha in forum WELDINGReplies: 7Last Post: 23rd Nov 2020, 08:17 PM -
Brass, Ally and steel material = Perth Pickup Only
By rodm in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 31st Jan 2019, 12:10 PM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
By thumbsucker in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 18th Mar 2013, 03:36 PM -
Any of you seen those decorative laser cut weathering steel light boxes
By beefy in forum METALWORK GENERALReplies: 21Last Post: 19th Jan 2013, 05:54 PM
