Results 1 to 6 of 6
    Nov 2017
    Geelong, Australia
    57
    2,651
    Default Your favourite inserts/holders for a larger lathe
    I've almost got the 21" DSG running, so need to get a couple of larger tools for general turning and facing to get me started. I don't want to be messing around sharing often used tools with my smaller Takisawa lathe (and they probably aren't ideal anyway).
    The only larger inserts I've currently got are WNMG0804's so I could grab a larger holder for those, but also thinking that SNMG and a PSSNR holder looks like a very useful style.
    Mainly for use on steel, as thats 99% of what I work with.
    Any recommendations from those of you who run larger lathes? What turning/facing tools do you use or like the most?
    Mar 2014
    South of Adelaide
    1,225
    95% of the od turning i do at work is with a TNMG16 or similar sized WNMG. 0.8mm nose rad for roughing, 0.4mm rad for finishing. Square insert in a 45 degree holder for chamfers.
    For boring we use TPMT inserts in sumitomo anti vibe boring bars mainly, these are probably a bit too much $$$ for a home shop but the same insert in a std bar would be fine. For larger bores we go to a tnmg or wnmg in a 40mm+ boring bar.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Thanks Snapa.
    Think I've got some TNMG's kicking around somewhere. Any particular holder style you mainly use for those for OD work?
    Mar 2014
    South of Adelaide
    1,225
    The holders we use have a 93 degree approach angle. I would also go with holders that use a clamp to hold the insert down, I'm not a fan of the ones that just use friction to hold the insert in place.
    Most of the tooling company's often have specials where you can get a free holder if you buy a pack or two of inserts. considering a holders is $90-100 and a pack of inserts is $100-150 its a pretty good deal.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Thanks for that.
    I've ordered a couple of cheap 32mm shank WNMG clamp style holders from AliExpress for starters, along with a cheap MSSNR holder and some SNMG's for chamfering.
    I see that M&G have the 93deg TNMG holders in a 25mm shank for $35 each so will grab a couple of those too and see which style I like best before shelling out for some decent holders and inserts.
    Mar 2014
    South of Adelaide
    1,225
    I think the cheap holders will work fine for hobby use. There isn't enough difference between a cheap and expensive lathe tool holder, for it to matter for hobby use.
  1. What is your favourite lathe chamfering/deburring tool?
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 9th May 2020, 12:52 AM
  2. Carbide insert tool holders and inserts
    By bollie7 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th Dec 2019, 09:41 PM
  3. Tnmg22 inserts and holders
    By snapatap in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 17th Apr 2018, 08:12 AM
  4. Favourite carbide inserts
    Last Post: 19th Sep 2016, 07:43 PM
  5. Plans wanted for Carbide Tip inserts tool holders
    By Jors in forum METALWORK GENERAL
    Last Post: 13th Nov 2010, 11:12 PM
