Results 1 to 10 of 10
Thread: Desktop water jet.
20th Sep 2021, 11:49 AM #1Member: Blue and white apron brigade
- 7,183
Desktop water jet.
In case you haven't seen it.
https://www.machineryhouse.com.au/W08720
20th Sep 2021, 02:21 PM #2Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
Oooohhh...nice.
I want one....lol
20th Sep 2021, 05:51 PM #3China
- Dec 2005
- South Australia
- 1,656
MMM! still a bit out of my price range, but it looks like a lot of fun.
20th Sep 2021, 07:14 PM #4Member: Blue and white apron brigade
- 7,183
I did a search on Aliexpress, Banggood and Bay for "Desktop water jet cutter".
These terms do appear on the auto search items for the first AE and BG which means others have been searching for this on these vendor platforms.
When you click on these it directs you to diamond wheel stone cutters.
If enough people search for them - my guess is someone may start making budget version of them.
21st Sep 2021, 03:30 PM #5China
- Dec 2005
- South Australia
- 1,656
Yeh and when the budget versions emerge there will be a myriad of hacks and mods to make them work
21st Sep 2021, 05:53 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
You’re going to be in for over 10k to build your own Plasma cutting table. An 18”x12” water jet in the back corner of the garage is somewhat appealing…..
21st Sep 2021, 06:18 PM #7Most Valued Member
- 2,651
Looks cool, but with max thickness in steel of only 3-4mm and 20mm/min cutting speed at that rate, not particularly useful in my workshop.
If it could cut 6mm++ steel at ~100mm/min then its getting useful IMO - so I'd still be better off with a CNC plasma
But if you're into thin stuff or non-conductives, then it would be an absolute ripper. I'd be up for some new way wipers for the lathe for starters
22nd Sep 2021, 02:23 AM #8
I checked that out on the H&F website . Read through the materials and speeds . Wood is not listed as one . Plastics and soft metals are listed so it would be capable of cutting say 12.5 mm wood wouldn't it ? Is wood not listed because water and wood is thought not to be good on W/J due to movement of the wood ? Or because of the mess cutting wood ? Surely not ? Or maybe because other processes cut wood better they think ? like spindle with cutter or laser? If laser cuts wood at all ? I recon W/J with wood has a use but don' know if its used at all . I'm interested to know that .
Id also like to be able to do Brass sheet which I'm sure would be OK . 1 to 2mm thick sheet .
Rob
22nd Sep 2021, 07:47 AM #9
I’m pretty sure they were cutting form ply in the fabrication workshop at Civil Eng at USYD last time I lunched there. They’re in lockdown currently so James or Theo aren’t there to ask.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
22nd Sep 2021, 08:39 PM #10Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
My boss said i could buy one for work if it cut 25mm plate, was very dissapointed when i read the specs.
Tig water cooling
By eskimo in forum WELDINGReplies: 3Last Post: 16th Feb 2018, 08:15 AM -
Water pump
By morrisman in forum AUTO RESTORATIONReplies: 4Last Post: 18th Jul 2016, 08:51 PM -
White Water?
By bigphill in forum METALWORK GENERALReplies: 4Last Post: 23rd Oct 2013, 09:30 PM -
Water lift
By rmm1 in forum METALWORK GENERALReplies: 26Last Post: 9th Aug 2011, 09:38 AM
