Results 1 to 6 of 6
Thread: Drilmor 13mm early 80’s service
20th Sep 2021, 10:25 AM #1Novice
- Dec 2013
- Australia
- 11
Hi all,
not sure if this is the right place for this question but….. I have an early 80’s Drilmor 13 mm.
drill press. I think that the spindle or quill has been bent. I know this seems unlikely but it was an ex high school machine and as an ex teacher I having seen what kids can do.
Any suggestions for checking the spindle runout ? Has any one restored one of these machines.
cheers
20th Sep 2021, 12:00 PM #2
Hi there Brett,
I can sympathise with that. Been there done that, got the tee shirt.
We had a Man Arts HOD who said on occasion. "The sods could break an anvil with a rubber hammer."
I liked the saying so much I applied it to my grandikds.
I see you have joined in 2013 and have only 2 posts.
You are man of few words, perhaps?
Checking run out on your drill press should be easy peasy. I think I would remove the chuck first, if it was me .Spindles can be staright but the chuck fitted to them may not.
If you have a dial indicator set its mag base up on the drill table and run the dial leg against the areas you wish to check.
If you have no dial indicator, clamp a wire pointer-can be fence wire, and old welding rod - basically anything rigid enough to support itself and set it on the base perhaps hold it with a drill press vice. With the drive belt off rotate the spindle by hand and look for an even gap as it is rotated.
If the gap is intermittent- narrow on side and wide on the other you have a bent spindle.
For the actual measurement you need to have a dial indicator.
20th Sep 2021, 12:09 PM #3
I googled and found some more info.
https://metalworkforums.com/f65/t204...drill-press-id
and
https://metalworkforums.com/f65/t206...1986-dismantle
First cab off the rank.The MetalWork Forums
20th Sep 2021, 06:39 PM #4Novice
- Dec 2013
- Australia
- 11
thanks Grahame,
I did not realise that I had joined so long ago. Quite the contrary it is often said I talk too much and certainly like a conversation. I am predominantly a wood worker so most Posts are on the ww forum. Thanks for your help I appreciate it. I cannot for the life of me remember how the chuck comes off the drilmor. From memory it is not a Morse taper until has something to do with the large nut under the chuck.
cheers
20th Sep 2021, 06:49 PM #5Novice
- Dec 2013
- Australia
- 11
thanks again Grahame,
I had already found the info from the first link by doing a search before I posted but thanks all the same. The second link was great as it reminded me how to remove the chuck. I will try that and set up a dial indicator if I can find mine😩 and check for run out. I guess it could be bearings too.
cheers
20th Sep 2021, 06:50 PM #6
Hi Brett,
If that nut above the chuck is what I think it is, then it is used to push the chuck off the taper ! If not then you might want a pair of wedges to remove it.Best Regards:
Drilmor M13 R9 1986. How to dismantle?
By Morpheous in forum METALWORK GENERALReplies: 2Last Post: 22nd Jun 2021, 06:40 PM -
Early Christmas
By wheelinround in forum METALWORK GENERALReplies: 22Last Post: 18th Dec 2019, 08:41 AM -
Drill Bits 1-13mm 0.1 steps
By HeavyMetal in forum WANTED TO BUYReplies: 20Last Post: 22nd Apr 2019, 09:58 PM -
Old Richardson Bench Drill Press (probably 1930s), 13mm chuck, Single phase.
By ml018 in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 27th Jul 2018, 05:10 PM
