Results 16 to 18 of 18
Thread: Hafco al320g lathe
24th Sep 2021, 02:46 PM #16Most Valued Member
oh ok, I get where it is now.
Back there I would say it will have even less effect.
ok good
24th Sep 2021, 06:16 PM #17Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Good to hear that Hare & Forbes want to help. The damage looks like a casting flaw and providing it's not really hollow in that section it shouldn't bother it. The more you pay the better quality you will get, but at the same time $3K plus is $3K plus the lathe should be able to function correctly and be accurate.
All The Best steran50 Stewart
24th Sep 2021, 07:49 PM #18New Member
- Sep 2021
- 1
I purchased my AL320G 7 years ago and whilst I had no 'sand in the headstock', the carriage was quite stiff in some places on the ways.
Your issue seems to be more severe than mine.
If I read this correctly, the area of concern is where the carriage gibs contact under the far side bed way.
In my case I oil stoned this 'underside' smooth and the carriage moved fine after that.
It seems to be common that many moving parts are not well lubricated from the factory - I took the top off the carriage and liberally greased/oiled most things and that further improved the general running of the lathe.
I broke 2 lead screw gears early on (the gear adjustment nut was loose) and H&F happily replaced them at no cost.
Dont despair, they are a good useful lathe and generally well regarded once the teething issues are sorted out.
Best to await the H&F person visit tho before you undertake any serious rectification work.
Lathe AL320G
By MacPuddock in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 23rd Oct 2019, 12:20 PM -
Using Collets on a Lathe (AL320G)
By Twisted Crank in forum METALWORK GENERALReplies: 8Last Post: 31st Jul 2019, 07:59 PM -
sell AL320G lathe Queensland
By leroy in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 29th Jul 2016, 05:59 PM -
Problem with AL320G Lathe
By burraboy in forum METALWORK GENERALReplies: 8Last Post: 17th Jan 2013, 07:51 AM -
AL320g Lathe CNC Conversion
By Holycross in forum METALWORK GENERALReplies: 2Last Post: 19th Jun 2011, 09:30 PM
