Results 1 to 8 of 8
    Sep 2021
    Melbourne, VIC
    5
    Default Stuck Lock Knob Bolt - Tablesaw
    I am restoring an old tablesaw - Woodman TS-222 (MBS-300) with sliding table attachment.
    The locking knob bolt on the main tracking wheel shaft of the sliding table is stuck fast, I think it's a little bent. Pics - https://imgur.com/a/m24EuWH
    The instruction manual is bare, but it seems the bolt is just sitting on top of the internal shaft (which also appears to be stuck tight). The side bolt then locks the shaft in place at the desired height. I need the wheel to rise about 1cm.
    I've tried squirting WD-40 into the threads, as much pressure as I can etc - But it won't budge. Any ideas?
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Welcome to the forum
    A bit of heat may help along with the WD-40.
    If you change your location, you might find a member nearby who could visit (bringing a large hammer or something) to assist in freeing things up. I think I know what you want to do from the picture, but nothing is better than a personal eyeballing.
    Sep 2021
    Melbourne, VIC
    5
    Well, half a result today - The bolt is free, the shaft is not
    Pics - https://imgur.com/a/FzgEN8s
    Managed to use a bigger pair of vice grips and wiggle the bolt back and forth and eventually got it to back out. The thread was just rusted and mangled..
    The shaft though, is still stuck fast. I tried using a hammer and steel rod to bang it out, nothing moved and I can't build a lot of momentum as the frame is in the way of a good swing.
    I then tried using a bit of steel rod and a car jack to try and force the shaft out and it wouldn't budge...the jack started bending
    So somehow the shaft that should be free-sliding is wedged in. Must be some rust, but wow it must be some thing to be that rock solid..
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    Welcome to the forum. I found Sea Foam - Deep Creep works quite well. A bit of heat with some oil may also do the job.
    All The Best steran50 Stewart
    Oct 2001
    ACT
    667
    I assume its the threaded rod with the plastic knob on it?
    can you get the plastic knob off and dismantle any further? As others have said, use some heat, but...
    get a few cycles of heating and cooling - must allow it to cool right down (do it four or more times), maybe even do it over a few days. you dont want it be glowing, but a few hundred degrees should be enough.
    though unless you can get it apart more it may be difficult to get the heat into the right bits, but no harm in trying.
    Jan 2004
    Mackay North Qld
    6,446
    Hi Flamingunz,
    Welcome to the MetalWork Forums
    We have a pretty good mob here who are supportive friendly and helpful.
    Please take the time to navigate around the forums to view the varied and interesting subjects.
    To do this, goto the the FORUM box in the top left hand corner of the screen. Click Forum Home and a scroll down page will come up.
    Scroll down the page and the various help pages and sub forums shall be shown.
    Please read the Terms of Use on the very top of the scroll down page - they are our rules.
    To save time here's the link
    https://metalworkforums.com/f90/t197...terms-tou-read
    Many pages also have a sticky at the top.If you post its always a good idea to check the sticky ,if there is one there.
    Again, welcome to our forums.
    Dec 2005
    South Australia
    1,657
    I am a big fan of Penetrene for such tasks
    May 2013
    Rockhampton, QLD
    68
    455
  1. Ball knob cutter
    By Grnman1147 in forum THE HERCUS AREA
    Last Post: 4th Jun 2020, 06:44 PM
  2. Please help! Stuck bolt.
    By steamjunkprops in forum METALWORK GENERAL
    Last Post: 27th Aug 2013, 11:56 PM
  3. In Defence of the Plastic Knob
    Last Post: 4th Jan 2011, 02:01 PM
  4. Small knurled knob
    By Tiger in forum METALWORK GENERAL
    Last Post: 27th Apr 2010, 12:51 PM
  5. Hercus 4-way tool post knob?
    Last Post: 25th May 2008, 07:00 PM
