Results 1 to 1 of 1
Thread: Gauss Meter for magneto magnets
16th Sep 2021, 12:22 PM #1Golden Member
- Dec 2007
- 574
A friend has some stationery engines - a few with weak magnets in the magneto, we are planning a remagnetiser and to try to make the project more technical I built this gauss meter so we can check our progress without having to resort to assembling motors etc to test for spark - I had all of the bits in my 'spares' bin except for the hall effect device, the info came from this web site.
https://rimstar.org/science_electron...display_ba.htm
Not having a digital panel meter that can be used with a single supply( ie effectively measure it's own supply voltage) I used a salveged 50uA moving coil meter that still worked fine but had seen better days. At power on the meter indicates 1/2 scale and deflects either to the left or right depending on the magnet polarity that is bought close to the hall device - the stronger the magnet field the greater the deflection, the LED's red or green are a quick indicator of the either N or S. I'll eventually get some nylon tube to protect the wires and hall device socket, being in a socket I can plug in more sensitive hall devices - the current device outputs approx 1.5mV/G, a strong neodymium magnet gives a deflection of around 2V either plus or minus depending on the magnet polarity. The hall device is not calibrated - the 1.5mV/G is only the typical output voltage for that device so all meter reading are only relative to each other - I believe calibrated hall devices are available so a calibrated meter could be made.
MIGS, TIGS & Magnets
By Blu_Rock in forum METALWORK GENERALReplies: 5Last Post: 21st Apr 2021, 12:57 AM -
lucas rs1 magneto
By dodge at4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 25th Sep 2017, 07:32 PM -
Remagnetise magneto
By sossity in forum ANTIQUE AND VINTAGE MACHINERYReplies: 13Last Post: 1st Jul 2017, 01:07 PM -
rare earth magnets
By fittermachinist in forum METALWORK GENERALReplies: 43Last Post: 18th Feb 2013, 10:50 PM
