Results 1 to 5 of 5
10th Sep 2021, 11:38 AM #1Most Valued Member
- 2,666
Mini-digger quick hitch plate drawing
Looking to make a couple of accessories for my son-in-law's Kanga mini-digger, and wondered if anyone has already drawn up the quick hitch plate and would be interested to share the drawing (for personal use only - not looking to make/sell them).
Pre-made plates are available on evilbay etc, but the cost starts to add up if you want multiple.
I'll draw some up from scratch if I have to, but no harm in asking the question first
18th Sep 2021, 08:05 PM #2Diamond Member
- Jun 2010
- Canberra
- 1,322
I made a rock bucket to go on a tractor's loader hitch a while back, and earlier in the week upgraded it so it'd fit on my Dingo as well. No drawings in this case, I just set the machine up to the bucket at the right height and tilt level, then welded in flat bar to engage the angled bit at the top, some angle to engage the bottom of the Dingo's plate and then some tabs with holes for the locking pins.
If you have the machine at hand, I'd be inclined to make up a hitch plate the same way - measure, cut, fit and weld in place. Maybe then measure everything for future reference. From memory the critical things are the angles at the top and bottom of the hitch.
18th Sep 2021, 10:17 PM #3Pink 10EE owner
- 6,218
Just remember that if you make one to fit your machine, it may not fit others where the hitch plate might less worn.
I had that experience, where a plate would fit my worn dingo, but it would not fit a near new one with unworn hitch plate.Gold, the colour of choice for the discerning person.
19th Sep 2021, 03:29 PM #4Most Valued Member
- 2,666
Thanks guys.
The top of the plate is angled so the machine hooks in, but the bottom is just a 90deg flange with slots for the retaining pins.
I’ll need to have a good look, as the slots may have originally been just holes
19th Sep 2021, 07:48 PM #5Diamond Member
- Jun 2010
- Canberra
- 1,322
The holes for the pins on the "proper" hitches are slots, I guess to allow for some sideways tolerance, and/or to avoid them taking any sideways load. I just drilled 16mm holes and the tapered pins seem to lock in fine.
Mini-digger bucket repair
By OxxAndBert in forum METALWORK GENERALReplies: 14Last Post: 15th Sep 2021, 09:51 PM -
Upgrading trailer hitch to electric brakes - what to do about base plate
By bishboy in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 11th Feb 2018, 11:43 AM -
Building a loader frame quick hitch
By .RC. in forum WELDINGReplies: 35Last Post: 4th Oct 2014, 06:25 PM -
Digger bucket
By spooled in forum WELDINGReplies: 11Last Post: 15th Feb 2010, 01:08 PM -
Kids play equipment. Monkey bars & Sand Pit Digger
By geocacher in forum METALWORK GENERALReplies: 15Last Post: 28th Sep 2007, 09:49 AM
