Results 1 to 9 of 9
Thread: Champher tool
2nd Sep 2021, 05:04 PM #1Most Valued Member
- 4,258
Champher tool
Watching some of Joe Pie" vidoes he uses a champher tool that does both outside and inside
Anyone know if these are available online and from where
Why should I have to be swapping tools out......
2nd Sep 2021, 05:48 PM #2Philomath in training
- 6,562
Got a picture? I have a carbide chamfer cutter that I use for inside and have ground up some HSS for outside use - could probably sort something out for you.
MichaelLast edited by Michael G; 2nd Sep 2021 at 05:49 PM. Reason: was HHS - blame the anesthetic...
2nd Sep 2021, 06:00 PM #3Most Valued Member
- 4,258
2nd Sep 2021, 06:54 PM #4Philomath in training
- 6,562
One of these?
I have one of these boring bars from General tools. The tip I have in it is for ACME threads (and the bolt in the front is a ring-in), but you could use one of these with a ground insert.
What it looks like he is using there is a carbide threading tool. The page is from Mcmaster, so you would have to cast around for a local equivalent.
Attachment 393796
If the GT boring bar idea looks a little flimsy, I could broach a 1/4" hole in a bit of square stock for you.
2nd Sep 2021, 09:08 PM #5Most Valued Member
3rd Sep 2021, 11:06 AM #6Most Valued Member
- 4,258
thanks Michael...I will have a look for that threading tool...if I cant find I know where to come
3rd Sep 2021, 01:26 PM #7Most Valued Member
I ground up a double-ended chamfering tool. Not as efficient as Joe's all-in-one tool, but works well. Make sure you grind plenty of relief into the end that does the internal chamfer.
3rd Sep 2021, 06:46 PM #8
YouTube restorer My Mechanics uses a square tool presented at 45 deg. for both inside and outside champhers. No repositioning required.
If you haven't watched any of his videos, they are worth a look.
Findlay.
3rd Sep 2021, 09:01 PM #9
For a lathe unless it's a small chamfer I find the tool chatters on larger ones and leaves a crap finish, so I use the compound with the lathe in reverse cutting on the backside.
Makes easy work and the compound is usually set around 45 degrees to keep out of the way of the tailstock.
Sent from my 5007U using TapatalkUsing Tapatalk
Hercus 260 quick change tool post and tool size
By Shaun@27 in forum THE HERCUS AREAReplies: 13Last Post: 24th Apr 2021, 10:45 AM -
Lathe Knife Tool and Boring Tool Sharpening
By metaler in forum METALWORK GENERALReplies: 30Last Post: 3rd Mar 2017, 08:38 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM
