Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
  1. #31
    Jan 2004
    Mackay North Qld
    6,177
    Quote Originally Posted by wm460 View Post
    I tried to take the valve off but I can’t budge it so will have to leave it.
    I noticed that this is extremely easy to press down don’t know if this is normal or if it’s bugged.
    There may be two reasons for this.
    Have you taken into account that the cylinder thread will be Left Hand. Fuel gas cylinders are Left hand Thread.
    I have removed valve bodies from half a dozen 9 kg cylinders- all LH thread.
    The brass valve bodies are often held by Loctite or similar and really take some moving.
    One sneaky trick is to use a large capacity electric soldering iron to heat up ( and soften ) the Loctite for 10 mins or so.
    I have made up a fitting which drops across the valve body and has a long handle welded to it.Just welded flat bar sections that drop over the valve body.
    Apart from that the only other problem is holding the cylinder in position so it won't turn as you apply leverage to it.
    Ratchet straps around the cylinder and a fence post will do it.
    I hope it helps.
  2. #32
    6,859
    I had the same problem and used a hot air gun with a restricted outlet, I have one that supposed goes to 650șC and it certainly did the trick
  3. #33
    Sep 2005
    Bendigo
    58
    239
    After seeing your post you had me thinking how I ever converted my 9kg cylinder, I checked my converted one and it is a standard brass 3/4 BSP pipe fitting in it.
    I then assumed that I must have tapped it and not remembered it, but then checked the two swap and go BBQ cylinders I have and both of them are right hand thread.
  4. #34
    Oct 2008
    Cairns, Q
    659
    I believe all Primus cylinders are also exceptions to this rule and have right hand threads.
    Frank.
  5. #35
    Aug 2011
    4,758
    Are you sure?
    The hose connection to all flammable gas cylinders are all LH threads but the actual valve group connection to the vessel are a standard RH thread.
    Edit: LH threaded connections have a V groove machined around the circumference of the hex spanner connection as an identifier.
  6. #36
    Aug 2011
    4,758
    Deleted post. Made a mistake. See above post. Making An Upright Air Commpressor From An Old LPG Gas Bottle.
  1. How to remove rusty 10mm bolts from Timber upright posts
    By Sterob in forum METALWORK GENERAL
    Last Post: 20th Jul 2021, 05:44 PM
  2. Upright metal BS stand
    Last Post: 8th May 2015, 08:51 AM
  3. How old is that gas bottle?
    By soundman in forum WELDING
    Last Post: 11th Dec 2014, 08:54 AM
  4. Replies: 6
    Last Post: 2nd Oct 2011, 07:13 PM
  5. Upright Bandsaw for cutting metal
    Last Post: 11th May 2011, 09:16 PM
