Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 98
  1. #31
    Sep 2006
    Australind , WA
    56
    1,067
    Exciting indeed.....Better than Christmas!
  2. #32
    Sep 2009
    Sydney
    538
    Soldering done and Iíve also managed to upload the software to the board. Annoyingly I donít have the cable for the control board so Iíve only been able to get brief sightings of the controls and how they work, but I am seeing what I would expect.
    I now need to cut a hole in my lathe control box for the display.
  3. #33
    Sep 2009
    Sydney
    538
    Quick setup in the garage tonight to cut the hole in my lathe control box for the ELS. Clamp the box on the mill and cut out the hole just following lines and roughly aligning it:
    Quick check before I break down the setup:
    Looking good!! I donít have a 3.5mm tap so I drilled the mounting holes out to 3mm and forced them in to the plastic.
    Worked fine and whilst itís a compact setup, Iím really happy with how itís turning out.
    My lathe controls and VFD are all on my right so I can adjust without any worry about getting caught up in the work. Having leadscrew control here is also really exciting and I cannot wait to give it a go!
  4. #34
    Sep 2009
    Sydney
    538
    Default Clough42 Electronic Leadscrew Implementation
    I went to Jaycar today and picked up some bits for the ELS. Specifically a 5v power supply for the TI board and connectors for the control panel.
    Annoyingly I bought the wrong connectors!! So Iím a fit of annoyance I soldered wires to both boards to see if it would work!
    Plugged in my new power supply and got thisÖ
    Woo hoo! It seems like Iíve managed to write the code to the board! All the buttons work as expected and the excitement levels turned up to 11!
    Iíve already desoldered the wires and cleaned up the pins with some wick. I also have some connectors in the mail. Hopefully theyíre the right ones.
  5. #35
    Sep 2009
    Sydney
    538
    A bit overkill but I now have the TI board in an enclosure, itís not water tight as I cut big holes in the bottom for the wires, but itís definitely dust resistant and will stop little fingers getting in there and messing something delicate.
    Iíve also installed a power board and the 48v power supply and VFD will have plugs put on and plugged in.
    Hereís the TI box with the lid on and I have everything wired up and the software updated with the final drive (I think):
    Just waiting on my connectors for the control panel, my encoder and the pulleys and belt for the drive from the stepper motor to the leadscrew.
  6. #36
    4,978
    Hi Neevo,
    Is the box lid on upside down ?
    Looking forward to seeing it running, nice work !
  7. #37
    Sep 2009
    Sydney
    538
    I donít think so BaronJ, it has all the gasket surface on the other side. Itís just a weird looking box lid Clough42 Electronic Leadscrew Implementation
  8. #38
    Sep 2009
    Sydney
    538
    @jack620 I implemented your idea today. Simple cap screw with a lock nut. Roughly set to 10mm:
    Crashing the indicator pushes the cap screw and then the whole indicator mount slides along the ways with the magnets.
  9. #39
    Sep 2009
    Sydney
    538
    Got a Cat5 cable today in preparation for my connectors coming in and what do you know, the connectors were delivered in the afternoon mail along with my main drive belt.
    Made the connections and routed the cable without any issues:
  10. #40
    Aug 2011
    4,596
    You've done well. Looks great and you did it pretty quick too.
  11. #41
    Sep 2009
    Sydney
    538
    Weeeeeeell, itís not actually working yet. Still waiting on the encoder to arrive and the drive pulleys.
    Once the encoder arrives I should be able to at least test to see if the configuration is working.
    I canít wait to test changing feed rate on the fly though to see how it affects the surface finish with carbide inserts. Also really keen to test metric threading
    Apparently in the future there are plans to try and get feeding to an automatic stop and also metric threading without having to worry about the issues with disconnecting the halfnuts. Those would be incredible!
  12. #42
    Sep 2009
    Sydney
    538
    Iím waiting on parts to arrive still and Iíve run out of jobs in the garage so Iím making up new ones to amuse myself whilst I wait.
    Pleased with my indicator carriage holder Iíve looked in to further options that will allow me to solid stop the carriage too. I could just create a hard stop but whereís the fun in that. So instead Iím going to try and make one with a micrometer (sort of) adjustment. The plan will be to have a graduated wheel with 1 turn equals 1mm
    Plenty of similar projects on the web so Iím just trying to make something similar.
    Ive made the rough shape in MDF and will look to transfer this to a block of steel I have on the way.
    This is the side profile:
    The rounded end is just a hair under 25mm so I can use 1Ē Alu stock and knurl it and trim it down a bit.
    The adjuster will be roughly this wide on the top with enough space either side for locking bolts. This is just to gauge the width, the depth is clearly not correct:
    Space is tight but Iíll have 2 M6 bolts on either side to lock it to the ways. Iíve already made the bolts and copied the square head of my lathe so I can use the same Hercus spanner on them. Iíve cleaned, wire wheeled and cold blued them already:
  13. #43
    Sep 2006
    Australind , WA
    56
    1,067
    Quote Originally Posted by neevo View Post
    'The' sign of a true tinkerer....lol
  14. #44
    Sep 2009
    Sydney
    538
    Quote Originally Posted by Sterob View Post
    COVID lockdowns have given me too much time at home so Iíve managed to clear my list of projects. Itís odd not having anything to do right now.
  15. #45
    Sep 2009
    Sydney
    538
    Damn I hate waiting for these last 2 parts. Dying to get it all together and see if it all works.
    However in the mean time I put the lathe back to standard so I could progress with the lathe stop. Pig of a job with the change gears which further makes me excited to get the ELS done.
    Iíd bought some steel and Alu for the stop:
    No real dimensions, just some templates that I used to create some scribe line. But thatís a solid chunk of steel and I wasnít sure if my newly converted bandsaw would cope:
    Needless to say it worked a treat. Thatís 40mm steel so itís slow and steady but I reckon I had all 3 cuts done in about 15 or so minutes.
    The cuts were relatively straight too but it was then in the the mill to get all the faces flat and square.
    A while on the mill to drill the 8mm cross hole for the stop, a threaded hole for a set screw to align with the key on the stop shaft as well as hogging out the centre.
    Then it was over to the lathe to knurl some Alu and drill as thread a hole. I really surprised myself on the Alu and not only got a perfect knurl but I also nailed the width with my new dial gauge carriage tool.
    Iíve also really surprised myself with the cold blued bolts which are looking fantastic too.
    Here it is, ready for the stop shaft to be made:
    Iím going to try and cut the gradations on the mill with my rotary table and dividing plates. Plus I also need to round off the ends of the holder and make the bottom plate.
  1. Electronic leadscrew
    By phaser in forum METALWORK GENERAL
    Last Post: 4th Jun 2019, 10:48 PM
  2. Calling all electronic gurus
    By Karl Robbers in forum WELDING
    Last Post: 28th Jan 2016, 08:31 AM
  3. Sieg C6 lathe - electronic leadscrew
    By snowyskiesau in forum METALWORK GENERAL
    Last Post: 11th Aug 2015, 11:12 AM
  4. Servo electronic threading
    By localele in forum METALWORK GENERAL
    Last Post: 31st Aug 2012, 11:21 PM
  5. Where to buy electronic micrometers
    By steran50 in forum METALWORK GENERAL
    Last Post: 11th Aug 2012, 03:22 PM
