Results 1 to 5 of 5
22nd Aug 2021, 07:13 PM #1Gear expert in training
- 34
- 1,075
Another worm wheel, but with more details
This came in a couple of weeks ago with a minor issue...
Perfect opportunity to learn how to measure up for a new one. Everything comes from the worm, from the top we have: Number of starts, axial pitch, OD, pitch diameter, helix angle, addendum, tooth thickness at the pitch line, and the gear train for our thread mill. We're only making the wheel, but it only takes a minute to add it in. Once we have the pitch, we'll check to see if we've done the same pitch before because that means we can simply copy much of the information; the only thing that will change is the helix angle and number of teeth in the wheel
Once we have that, we can then work out everything else.
Then it's off to (hopefully) find an existing tool bit. We've cut this pitch before, so there's a good chance of finding one
Got a bit, time to set it up. All we're doing, in theory, is creating a single point of the worm that will cut the teeth to match the exact profile. As you can tell from the shifter and hammer used to actually set the thing, being a few thou or 10 minutes out isn't going to make a whole lot of difference in the real world. The tool bit is held in place by a screw in the end of the bar clamping against a stack of dowel pins.
Because we can't measure the size of the wheel directly, we have a simple fixture that sits on the hob slide to hold the worm in tight mesh, then we can take a measurement from that with gauge blocks and calculate the remaining depth of cut
Didn't get any pics of checking the fit in the gear tester due to time, but it's pretty simple; wheel sits on the pin, worm is held across it (usually between centres, but this one didn't have a centre in one end so it sat on the V-blocks on the ground bearing diameters), they're brought to the nominal centre distance and we make sure they run freely.
All deburred and ready to go.
PXL_20210819_230914172.jpgGear cutting specialists and general engineers www.hardmanbros.com.au
22nd Aug 2021, 07:41 PM #2Most Valued Member
- 5,942
Nice to see that you're getting a bit of variety in your work.
22nd Aug 2021, 08:03 PM #3Gear expert in training
- 34
- 1,075
Sometimes we go for months without one, sometimes we get one a week I'm glad there's lots of them now, means I can consolidate what I've learnt before the last guy who knows anything about it leaves
23rd Aug 2021, 05:55 PM #4Most Valued Member
Nice work. Can you tell us the cost of that part?
23rd Aug 2021, 06:14 PM #5Gear expert in training
- 34
- 1,075
Nope, but I can have a guess...
They ordered 2 of them, so lets say 1 hr for measure and calculations, 3 hrs to turn and slot the blanks, 6 hrs for gearcutting at $120/hr (not 100% sure on the shop hourly rate, but that sounds in the ballpark) comes to $1200, plus material, plus the "tear down the job that's already set up because we need these now" surcharge... Might be looking at $2k for the pair
I'll try to remember to ask out of curiosity, might not get an answer thoughGear cutting specialists and general engineers www.hardmanbros.com.au
My first fly cut worm wheel
By elanjacobs in forum METALWORK GENERALReplies: 3Last Post: 24th Jul 2021, 09:57 PM -
Machine a worm wheel for my borer.
By steamloco1954 in forum WANTED TO BUYReplies: 0Last Post: 18th Jan 2020, 01:31 PM -
need a worm wheel
By steamloco1954 in forum METALWORK GENERALReplies: 7Last Post: 21st Nov 2019, 05:23 PM -
Worm & wheel gears
By nadroj in forum METALWORK GENERALReplies: 19Last Post: 11th Feb 2019, 10:23 PM -
Imperial worm wheel on a metric leadscrew
By funkychicken in forum METALWORK GENERALReplies: 11Last Post: 6th Jun 2009, 04:33 PM
